Rotary Cutter Size Matters
/ Size Matters #1
DanielJ
Member
Tyler, TX
John Deere 5625
Need some advice on rotary cutters. I am looking at buying a 80'ish HP tractor and a bush hog. I am told that the cutter should "cover the tires". That means 77 - 80 inches and a 7' or 8' cutter. I've had some advice that the 84" mowers protrude so far behind the tractor that they can be difficult to maneuver in tight places.
On the other hand the double headed 8 footers don't protrude so far to the rear but are more expensive and really seem wide.
Some sage advice would be appreciated.
/ Size Matters #2
I have a Kubota M8540 tractor. I think my R4s sit about 7 1/2' wide but I use a 6' cutter. I was going to get a 7' cutter but decided against it because of the size of that 7'er... it sticks WAY out the back!
I considered an 8' (dual spindle) cutter but decided it was too big to fit in my garage. If I had the space, I would have bought the 8'er.
My 6'er isn't wide enough to "cover my tracks" but that hasn't been an issue for me. Now that I have used my cutter several times, I really like the size. I can maneuver it in places that a biger cutter would prove difficult.
/ Size Matters #4
We sell dual spindle cutters and single spindle type of cutters. Only use dual spindle, if you need that extra cutting width. They have 3 gearboxes on them and also connections between the outboard and center drivebox to maintain. The single spindle 7 or 8 ft is a lot less expensive to maintain and cost less. Ken Sweet
/ Size Matters #5
I use two cutters on my 80 HP tractor, a Woods 121 10' 3-point hitch and a Woods DS1260 10'6" pull type. The 121 is really pretty maneuverable. The pull type is a really good cutter, but not very maneuverable.
We got the pull type to cut the heavier stuff the 121 wouldn't handle.
/ Size Matters
Thanks to RJ, CharlieS, Ken and RRR for the help. It's nice to get advice from people who have been there and done that. Thanks again.
/ Size Matters #7
Good luck. Have you given any consideration to a flail?
/ Size Matters #8
Your welcome and let us know what you do and maybe post some pictures. Ken Sweet
/ Size Matters #9
My thought also. You can get an 8ft flail that will cover your tracks without the long overhang on the 3pt hitch.
265/75R16 New Tire (A62613)
265/75R16 New Tire...
6ft Teakwood Indian (A65583)
6ft Teakwood...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
John Deere 4044R (A62177)
John Deere 4044R...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
