445 long tractor hydraulics issues
/ 445 long tractor hydraulics issues #1
gary yarbrough
445 long
Hi everyone, I have several questions on the 445 long tractor. i recently bought one from a JD dealership and suffice it to say it is a little bit different from any of the other tractors I have owned:confused2:, they have no clue on any of the controls or service locations on the unit re: Hydraulics service, pump locations filters location etc, or what the function of the gears location is. I shows 5 speeds and 2 reverse's, but I can only get 3 speeds out of it and 1 reverse. Now past the ramble, does anyone have any diagrams on the floor controls, the serviceable locations on the hydraulics, and any other points of interest. This is just a bulky old tractor, but I want to make sure that it is serviced and/or repaired correctly. Any help would be appreciated. Thanks Gary Y
/ 445 long tractor hydraulics issues #2
:welcome:
It is a Long tractor, not a long JD 445 tractor. :D
Had me going for a minute.
/ 445 long tractor hydraulics issues #3
Please show a picture. Long sold tractors built by Universal (Romanian Fiat license) Zetor and other brands. I guess yours is Fiat based but who knows for sure...
I am aware that it is a long not a JD, it was a trade in at a JD deaalership, sorry for the confusion.. Gary
/ 445 long tractor hydraulics issues #5
Maybe they'll tell you how to reach the former owner who can advise you how to use the thing. May even tell you what's wrong with it!
Jim
/ 445 long tractor hydraulics issues #6
Hello, and welcome to TBN. Being a past Long dealer. I can help. First, get a copy of the owners manuel. Alot of useful information in it. Their are pasts forums on here with discussions on them. I might be able to get you one from my wholesaler but that is hit or miss. A 350,360, and 445 2wd are pretty much the same tractor with different HP. They had a10" clutch with a 6x2 tranny. The engine is 143 cu. in. with 41 pto hp. A 7/8" wrench removes all the drain (fill-1) plugs underneath the castings. Engine drain is on lower oil pan plate. Tranny drain is below the shift lever. Diff drain is just ahead of the drawbar. Fill plug is left side of gear shift lever which fills tranny, hydraulic, and diff. housings( About 22 quarts cap.). Any good quality universal tranny- hydraulic oil will work. If this is your first tractor, use extreme caution and get to know it. Operate it and know it limitations. They were a good old tractor from the 70's.
Thanks for the info Trac, The machine is an older unit, but seems to be working well for what i gave for it with a large front end loader. If you can find out any information on the manual, you can email me at gyarbrough57@hotmail.com. Again thanks for the info Gary
HI My name is gary yarbrough, we made contact in june 2010 about a long 445U tractor. You explained the hydraulics questions I had, but I am just getting aound to servicing the unit since I bought it. This must have been a tough old bird since I think the previous owner must have hated it, but just could not kill it. You stated that the hydraulics hold 22 quarts. My question is I can drain all the casesindividually, but can I fill them through the one 7/8 plug on the shifter plate, and will this fill all the cases (transmission/differential/hydraulic res) If this is the case, then my understanding, from what you origianlly told me is that they all use the same trans/hydraulic oil. Also, is there s filter in the hydraulic system which needs to be replaced, and if so where is it I finally have a lead on a service manual, and I thank you for you assistance. You can email me at gyarbrough57@hotmail.com. ps: I have finally figured out all of the levers except one, it is a cresen t shaped lever below the lift control, and it operates what appears to be an excentric cam mechanism. Well, thanks again and you can email me whenever you get the time. Gary
/ 445 long tractor hydraulics issues #9
I had a 460 a few years back.
The hydraukic pump is on the right side driven off the engine. there are metal lines from the pump to the lift cylinder under the seat. The hydraulic filter is in the larger metal line from the assembly under the seat to the pump. The filter is cleanable and reuseable generally (wash with diesel look for excess metal filings).
Pressure check the pump with a guage mounted on a remote plug using your remote lines. probably 2000 psi or so is ok.
The cresent shaped lever may be the speed control or flow control.
/ 445 long tractor hydraulics issues #10
I just bought a 73 model Universal 445 and it came with a manual. It also came with a very large lubrication chart printed by UTB. The chart says to use 85W EP transmission oil in the hydraulic lift. I have always used hydraulic oil in my other 445. Is this recommendation correct? I'm thinking about changing my hydraulic oil to gear oil. Has anybody else ever heard of this?
/ 445 long tractor hydraulics issues #11
I put 75W gear oil in my 445 & it worked fine. I think that any of the Fiats with the insertable strainer in the return line are supposed to have gear oil in the hydraulic system. That crescent shaped lever is the draft control. Your only supposed to move it when the lift is up. "Up" is "draft" & down is "lift". The draft will only work if you remove the spacer from in front of the toplink spring.
/ 445 long tractor hydraulics issues #12
Thanks for the info, I have a Long 445 and the Bush Hog will not lift. It has been sitting for some time, and I really needed to know how to add hydraulic fluid. Thanks,
Steve Bisson
/ 445 long tractor hydraulics issues #13
I am taking care of a Long 445 in NH. I drove it recently and the bush hog will not lift. From other threads today I have discovered how to add hydraulic fluid so that it should work ok. Is there any way you could scan or copy that UTB lubrication chart to me? I have the service manual on order but any info or pdf file on the Long 445 would be greatly appreciated. Thanks!
Fax (502) 243-1832
email: stephenbisson@mac.com
/ 445 long tractor hydraulics issues #14
Fax (502) 243-1832
My 445 does this also. Don't know why but it happens when the lift goes all the way down and sits for a while. If I have an implement on the back I just lift it with the loader on my other tractor. It's fine once the arms come up a little.
/ 445 long tractor hydraulics issues #15
The position control external linkage would freeze up. Follow the position control lever down under the cover, u will see the linkage and rollers. Spray with a good quality pen oil first, then a lub oil their after. This is a built in option, that was incorporated in the UTB design. We fought the Romanians tooth and nail, but they never would improve it.
/ 445 long tractor hydraulics issues #16
I have a U445 with an auger attached to the PTO. I have not used the auger since last year and I am now having an issue. The auger will only drill about 6 inches. It seems like the Hydrualic lift arms are not pushing the auger down. Does this have something to do with the draft/position lever. I have the lever in the down position but it still does not work. Any ideas.What should I check for? Can anyone explain the draft/ position lever function.
/ 445 long tractor hydraulics issues #17
Does anyone know where to get a PDF file for the long 445 owners manual
/ 445 long tractor hydraulics issues #18
the tractor i have has it also and i think its for a hydraulic outlet, but i use it to bleed the hydraulics when their not working.
/ 445 long tractor hydraulics issues #19
Manuals can be bought from jensales, link if it works. http://www.jensales.com/search.php?search_query=Long+445
Regarding the three point hitch, it dose not have any down force, gravity only. It is the post hole auger that pulls itself into the ground, perhaps it's damaged / worn out.
/ 445 long tractor hydraulics issues #20
Check the two "starter bits" on your auger. One in the very center and one on the bottom of the corkscrew. Doesn't take much for them to wear out. I have both a 445 universal and a 510 Long. Service manual is for the 510 and a couple of other smaller models but most of the tractors are the same. PM me with an email address and I will see if I can email to you. Not great graphics because it was a free download I found somewhere but better than nothing.
2011 TRAIL KING TK70MG-523- 52' LOWBOY TRAILER (A65054)
2011 TRAIL KING...
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A66736)
2018 International...
2025 SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A66734)
2025 SZYMJ...
PORTA POTTY (A68842)
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
