JD 3720 rear fenders
/ JD 3720 rear fenders #1
TC33DA
Member
North Carolina
I ordered the 6" extenders for my cabbed 3720. I would like to add the JD rear fenders but not sure how they fit and how they are attached. Anyone know? They look like they are about 2" black plactic, Might help with the wheels going out 6".
/ JD 3720 rear fenders #2
I have the front and rear fenders on my 3720 cab tractor. I will measure the rear extensions this afternoon and post.
/ JD 3720 rear fenders #3
My 2007 3720 cab tractor has the smaller R4 tires with rear fender extensions which are fastened to the fender with 4 bolts on each. The width of each extension is 2-7/8 inches. The outside fender extension edge is wider than the outside tire tread edge by 1-3/4 inches.
Mine were installed by the dealer and it appears to be a fairly easy job.
Thanks for the info. I wondered how they attached because the fuel tank is on the left side and not much room to work with. I am installing the 6" extensions this weekend. If needed I will order the fenders,
Thanks
/ JD 3720 rear fenders #5
Thanks
I also have a 3720 cab with fel and 72"HD bucket. I Installed the 6" spacers on mine but I flipped the wheels side to side to the narrow spacing, this really made it so I was add 5" on both sides. By doing this my rear tires are just slightly inside the width of the bucket.:thumbsup:
/ JD 3720 rear fenders #6
Anyone dare to post pics?
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2016 John Deere HPX Gator 4x4 Gas Utility Cart (A61567)
2016 John Deere...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
