JD 850 tractor hyd filter clogging up
/ JD 850 tractor hyd filter clogging up #1
Charles LeBlanc
John Deere 850
I have a 1981 JD850 over the past several years I have been having 3 ponit lift problems. The trans/hyd oil turns milky and the screen clogs up. I have had the pump rebuilt once and drained and refilled and cleaned the screen several times. This seems to be a temporary fix with the interval between problems getting shorter each time. When the tractor is cold it operates fine but when the oil warms up I can hear the engine mounted pump cavatating and the lift becomes sluggish then quits all together.Any ideas?
/ JD 850 tractor hyd filter clogging up #2
I think you need to cover the tractor if left outside. That will help prevent water from getting into the tractor. Change out the hyd filter more often. Put a pressure gage in the system and it will help you analyze your problems. Check for leaks at the pump input.
Are you using the correct hyd fluid ?
/ JD 850 tractor hyd filter clogging up #3
Welcome to TBN:D
Sounds like water is getting in your sump somehow, that is why the fluid looks milky. This must be addressed before anything else. Is the machine kept outside?
/ JD 850 tractor hyd filter clogging up #4
I third that guys. Charles, D.T.S. (Department of Tractor Services) may get you for cruelty to your green paint!!!:D Oh! and welcome.
2025 KENWORTH T880S DUMP TRUCK (A63276)
2025 KENWORTH...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A67148)
2021 UTILITY VS2DX...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2016 Isuzu NPR 20ft Box Truck (A64556)
2016 Isuzu NPR...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
