need help with hydraulics
/ need help with hydraulics #1
joe woodum
satoh 655g
just got a satoh tractor s650g with front loader bucket 3ph and a pto. having an issue with hydraulics it works but very jumpy and sluguish. i've been told to check out the filters and fluid levels.fluids seem to be ok a little clowdy coffee coloured will prob put new oil but can anybody tel me were to find filters or do i have a screen and were would that be located.and were the vent are and how do i clean? any help would be apprecitated thanks! joe
/ need help with hydraulics #3
Welcome to TBN:D
The coffee colored fluid is most likely your problem, it means that the fluid has water in it. Can't help with filter locations and such-but you need to change that fluid and find out where it's getting in the system.
/ need help with hydraulics #4
check on the case under the rear wheel area . look for 2 bolts that is holding down a oval shaped plate .this may be on the brake pedal side.put a large pail under there and open the bolts. remove the plate and screen.wash the screen with solvent and soft brush.put back together with new fluid.
/ need help with hydraulics #5
Black coffee color> burnt fluid
Chocolate milkshake color> moisture in fluid
Either way the fluid should be changed and the screen serviced
I ordered some parts and a owners manual from Valley Power and was
impressed with the person I talked to (Bill) he was a bid help and has
alot of knowledge of Satoh tractors. Their email address is below.
satohparts.com
/ need help with hydraulics #6
I have a 1971 satoh 650g and if your tractor is anything like mine , you will need to drain the hydraulic tank under the seat ( holds about a gallon) . The screen is at the bottom of the tank . You will need to remove the large bolt holding the steel hydraulic line to get the filter out . The filter is a piece of pipe surrounded by a fine brass screen .
/ need help with hydraulics #7
having an issue with hydraulics it works but very jumpy and sluguish. thanks! joe
Milky oil, jumpy and sluggish could be air entrainment from bad suction hose/tube/fitting/pump shaft seal....No????....jumpy and sluggish kinda gives it away as air suction leak and/or cavitation.......
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
INTERNATIONAL 674 TRACTOR (A64276)
INTERNATIONAL 674...
HANFAB HF-60-DG1-SD-R 60" CIRCULAR SAW (A64276)
HANFAB...
