Goalie
My 5210 radio is not keeping time. When running it works fine but when the tractor is shut off and sits for a few days the time is not correct. It use to work fine. Any ideas on what is wrong?
I'm not familiar with the JD radio you refer to, but being an elec. tech most likely there is an on-board battery mounted onto the pcb (printed circuit board) inside the radio that provides DC voltage to keep the clock chip running when the tractor is shutoff. Most of the time they have a charge circuit but sometimes the battery just goes bad (like your car/truck battery goes bad every 5 years). This is really no different than a clock built in to the radio in your ford/chevy/gm/whatever. Sometimes these batteries are easily replaced (snap in/out), sometimes they are soldered in. Only your JD dealer knows for sure. If digital time is really that important, I suggest you go buy a cheapy stick on digital clock and stick it on the dash, or wherever suits you best. To pull the radio out and replace the battery could cost more than you would be willing to pay, unless it's under warranty.
Bill,
When my tractor sits for two or three days with the key off when I start it the time is wrong. I set the time on the radio as the tractor is running and it works fine. If I shut the tractor off and start it back up it keeps perfect time. It is only when it stits for more than a couple of days without running. As for the preset stations as far as I can remember the radio always stays on 100.3 and never resets no matter what.
Goalie
