Need help configuring a Kubota M6040/7040
   / Need help configuring a Kubota M6040/7040 #21
My youngest son and I both drove it and really liked the parking brake. I especially like it as when my sons set the brake on our other tractors I often have to use my cane to pry up while pushing the button to get moving.
Yes the brakes are nice especially in comparison to what we now have.
I will check on the cast iron wheels, but if I delay too much or go up in cost from our present price the CFO may decide to just fix our old tractor:(
We all know the CFO situation!
On the M8540, the cast iron wheels are $912 more than the standard steel wheels. They get slightly cheaper the BIGGER you go in tire/wheel size. I don't know if you noticed, but on the M8540 you get the following tire/wheel sizes in R1s:
Front: 11.2-24 Rear: 18.4-28
Front: 12.4-24 Rear: 16.9-34
Front: 12.4-24 Rear: 18.4-30
Front: 12.4R24 Rear: 18.4R30 (radials)
You guys running R1s are lucky, you get a lot of tire/wheel options. Kubota only offers 1 size for R4s for a given tractor.
   / Need help configuring a Kubota M6040/7040 #22
Thanks for the information, I checked on the tires yesterday and they were as above. They are Titan brand which I think is pretty standard on Kubotas.
   / Need help configuring a Kubota M6040/7040 #23
Bulldogger,
I noticed in the posted pic of your M9540 that you have/use the Quicke loader. Would you mind sharing why you chose something other than a "matched" Kubota loader?
All very nice equipment. I'll add that I noticed in the background of the picture ... the new wood barn looks fantastic. -Thanks for sharing about the Quicke loader.
   / Need help configuring a Kubota M6040/7040 #24
We have a tractor down and work that has to be done for my sons' business, so I am going with the one in stock; should be delivered next week; thanks to everyone for the input/information.
   / Need help configuring a Kubota M6040/7040 #25
Bulldogger,
There are some more pictures of the barn in this post http://www.tractorbynet.com/forums/...73491-kubota-finally-got-delivered-today.html at the bottom of the first page.
The biggest reason I went with the Quicke loader is it will lift more weight than the Kubota loader. I frequently lift pallets of sod and retaining wall block that are really heavy and the extra lift capacity helps. This is my third Quicke loader and I really like them. I believe that it cost about a $1000 more than the Kubota loader so I can't say I did it to save money. I hope this helps.
   / Need help configuring a Kubota M6040/7040 #26
Bulldogger,
Thanks for the link to the pictures. I showed them to some friends, and your work and the finished barn certainly earned the admiration of all.
The Quicke loader is intriguing. I have just sourced a used L5740 with the Kubota 854 loader that I like and the price is good. The capacity of the 854 loader does concern me also, but the Quicke literature that I found led me to believe that Quicke does not make a loader for the L5740. The larger M tractors are appealing, but I don't think the size of the tractor is suitable around the horse barn or near the creeks and stock ponds. The M59 has the loader capacity that I want, but I just don't think I'll be happy with its performance as a pasture tractor.
Thanks for all.
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
