compact TLB vs. full size TLB
/ compact TLB vs. full size TLB #141
mike69440 said:
Grading is real tough, even with a dozer. A 6 way blade is the nuts though. My wife is getting pretty good. I will have to post some photo's of her work.
I do ok with a loader or excavator.
I have a CAse 450 w/ 6-way. I just need to practice more with it. Today in fact. I just can't get the knack of it - looks and feels great when I'm in it but when I look back over it I'm not even close.
If I'm careful I can do a better rough job with my backhoe. I know this isn't right so I need to work on my trechnique.
In fact, grading is the hardest thing I do - general grading on the farm and around buildings (this is a farm partially on a hillside).
/ compact TLB vs. full size TLB #142
It would interesting to hear from someone who has mastered the blade. I know it's all about starting and staying level and keeping dirt in front of the blade. The rest is timing. When I use a box scraper I can anticipate change, but with the dozer my adjustments do not make the grade.
jmf
/ compact TLB vs. full size TLB #143
jmf
Thabt's exactly what it is for me. I can't quite get the feel for holding grade and ending up w/ what I want.
practice I think, just more practice.
/ compact TLB vs. full size TLB #144
jmf
I thought it was quite easy. :confused:
Builder said:
You could easily do it yourself. A dozer is easier to master than a backhoe. You could have a rental unit dropped off at your building site and have at it. Give yourself credit, you seem like a capable guy. :)
Haha.. thanks for the vote of confidence.
I think I could probably get a road cut in with a dozer, but I don't think it would be pretty. I think I could do a much better job with a backhoe w/ 4n1 bucket and a tractor w/ boxblade.
/ compact TLB vs. full size TLB #146
I find that if I turn the blade at the extreme angle and then lift the most forward tip slightly, so that the forward tip is about an inch off the ground the trailing edge is digging in . This also allows the blade to travel over humps at an angle which smooths them out easier. I travel one way and then return on the oppisite side. I end up with a road that looks as of a maintainer had done it. Remember to take the least amount of dirt load that you can and it will be enough- to your surprise. Hope that helps.
rick
/ compact TLB vs. full size TLB #147
That's an interesting tip. Does this apply to loose or settled ground? Do you also find that it is important to keep the machine level?
jmf
/ compact TLB vs. full size TLB #148
It does make a difference if it is loose or hard - however if you don't get in a hurry the angle will keep you from make those humps that seem to occur so easily. I have my hand on the control all the time and will make small height adjustments as I go. After a few passes the road is level and then the dozer will stay level with very little input from me as it follows the ground. You relly get in trouble when you try to DIG the dirt instead of sculpt it. I have decided that I can always take half the bite I want to and it works much better, and it also makes the job go faster in the end.
rick
P.S. On a side note the loose stuff really responds well to backdragging with the blade angled with the rear side of the blade higher and the blade set in the float position. The faster gears for this seems to offer a smoother finish.
/ compact TLB vs. full size TLB #149
I'm obviously a little late here, but the fact that I'm even reading this thread shows that the TBN information archive is a living thing.
If anyone is considering working a large parcel of land -- from the ground up ;) -- you cannot go wrong with a full size backhoe. And if you have a tough parcel of land, as we do, you will be very glad you invested in a 4x4 machine. Our land has a few terraces in the topography, but it generally climbs a small mountain. Add the large amount of precipitation we get in this part of the country, and you've got some tough operating conditions.
And as Builder detailed back when this thread was started, you can get very creative with how a machine like this can be used -- you will end up surprising yourself.
I've never owned a TLB, but once you've tilted either end of a 10 ton machine up to the 20 degree region -- due to the sheer weight you're working on -- you'll know that a machine can never be too big. I'm sure that smaller machines work great for certain jobs, but I can tell you, from experience, that construction type work usually requires serious brawn.
Just my two cents... :)
/ compact TLB vs. full size TLB #150
I am new to BH's but I was taken back how our 13K pound 1983 JD 310B seems to be on the light side unless stuck. :D
After a person has everthing perfect with no more dirt to move in a major way the lighter machines might rule. I used our hoe only to pull out the heavy 265 MF the other day and the MF was not even running. Well it was my 12 year old son who did it as I watched. The kids are better on the joy sticks than dear old dad. :laughing:
/ compact TLB vs. full size TLB #151
Ain't that the truth..!! :D
AKfish
/ compact TLB vs. full size TLB #152
That's great, Gale. I'm very happy to read that someone that age has been taught to operate a machine like that: good for you! :D
Pulling out another machine is one thing, but how about when you get your own 4x4 backhoe stuck? I've been there, and that's when you have to get creative, and "...find more uses than you can imagine." -- DirtyWorks ( in Post #7 )
Have a good one down there ...
/ compact TLB vs. full size TLB #153
Have a good one up there ...
Our son and daughter turn 13 in Sep and both wanted to did a hole the first day we got out on the BH. They both were better than me at the controls for sure that first day. :)
They are developing seperate interests natually but Austin is really interested in tractor driving. So is Heather but her size and build makes a full size tractor a little much for her brake and clutch wise.
I hung the 265 MF when I rolled backwards too far mowing off the tops of grass in a ditch cut a few years ago by a 36" trackhoe bucket. I slipped the tires about 6" forward and backwards but with both tires in the trench and the bush hog tight on the ground I was hung tight. Yes I have learned when in a hole I do not want to be in to STOP digging. :D
I was only 1/2 mile from the house and another guy was there watching roofers on the church so I got him to run me up to the house and Austin and I went back down on the BH with chains.
He was eager so I decided to do nothing but to stand aside and coach him through the operation. I had spotted the BH and let out the boom but that was all.
He got the MF out of gear, connected the chain to both the MF and BH bucket and then set up the BH on the pads correctly. The BH has a hitch welded onto the back of the bucket and he worked it out nicely. I have him to run it at about 1000 RPM when doing a recovery like that. He had seen me do this operation about a month ago.
What was really cool for him he got to drive his late grand dad's MF back home following me driving the BH. By cutting across some fields we never had to cross the state highway and was only on the wide shoulder a short distance. He did well and stayed in good control.
Our kids are important to us and being about 45 years older than them I think makes us aware our years together may be limited and we need to pass on every skill possible when we can safely do so. In some ways I would be better off in a physical sense not to be messing with the tractors, truck, trailers and implements but it is good training for the kids.
They are in on most all of the servicing and repair of equipment, motorhome and other things around the place. They both can find their way around TSC quite well. :)
On the BH it is a 4x2 but so far I have got it out of what I get it into but it has maxed out my brain a few times. I am going to try to clean out the 36" ditches but that is going to be a task to get and keep center of the ditch. I have done a little practice of moving the rear wheels side to side with the hoe. The FEL will help me float the front axle I know. I guess I need to rewatch some of the Youtube dancing BH videos. :)
/ compact TLB vs. full size TLB #154
Never though of an L39 being that 'inadequate'. Interesting thread - I learned alot.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
HYSTER H30XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H30XL...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
UNUSED FUTURE FT-X39 MINI HYD TRENCHER (A62130)
UNUSED FUTURE...
