Temperature gauge JX95
/ Temperature gauge JX95 #1
Bob Hall
JX95 IH
I have a JX95 and my temperature gauge is not functioning. I have power at the sending unit and I have power at the gauge. I tried plugging in a new dash cluster and the gauge did not work on it either. I then put a new sending unit on the plug and put it in water that was at least 180 deg. and it still did not work. I then plugged the new cluster in with the new sending unit and that still did not work. At the back of the gauge there are 3 terminals or studs in a triangular pattern. The center one is ground one side is full voltage and the other is the sending voltage and I have current on both sides. Does anyone have a clue.:confused2:
/ Temperature gauge JX95 #2
If the sending unit has only one wire leading to it, your hot water test is invalid. The sender would need a return ground path added, as the tractor chasis and engine provide a ground path when the components are installed.
I think your sender is bad and you have not tested it properly.
There are 2 wires going to the sending unit and when I performed the standalone test putting it in a cup of hot water there was 2 wires going to the sending unit unless you think that quite possibly the unit still needs to be grounded also. it is a possibility I will check it out.
water pump housing
Cool, thank you very much. I was starting to think I was crazy or something. That makes total sense.
213078 (A64276)
213078 (A64276)
2006 Shamrock 10ft. S/A Enlcosed K-9 Transport Trailer (A61574)
2006 Shamrock...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
