Problem with Kubota LA724 Loader
/ Problem with Kubota LA724 Loader #1
SteveCornell
Weston, West Virginia
2017 Kubota L6060 HSTC
This evening I was rooting out some brush with my grapple when something went "POP" in my loader, now I do not have any curl power, I can curl down and I have power and it holds but when I curl back all goes limp and I have no power back.
I think I damaged something in the cylinders, any ideas ???
/ Problem with Kubota LA724 Loader #2
Curl cylinder is retracting on curl backward!!
Bucket curl forward!!
Does bucket move anything on curl backward??
If NO for backward, piston most likely came off the piston rod inside one of the the cylinders....."POP".....:D
Yes, that is what I suspect, I can lift the front of the tractor off the ground and the valving will hold it in place (extending cylinders out) but there is nothing when I try to retract the cylinders...... Sound like I broke both piston rod ends..... I'll have to remove the cylinders and get them rebuilt :(
/ Problem with Kubota LA724 Loader #4
one piston off is enough to disable both...they are plumbed parallel... if you have a couple plugs for the hoses you can determine which cylinder is bad....OK? do that before starting dismantle the "whole" machine....unhook the hoses on one cyl..,.and check if FEL runs "normal" with the other cylinder....
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2015 GMC Sierra 3500 HD 4x4 Crew Cab Flatbed Truck (A64556)
2015 GMC Sierra...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2006 Isuzu NPR Box Truck, VIN # JALB4B16567020383 (A65563)
2006 Isuzu NPR Box...
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
