TuffTop Bracket Cracks
/ TuffTop Bracket Cracks #1
Rusty
Gold Member
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
First, let me say that I love my TuffTop canopy. I certainly would not want to be without it! My TUFFTOP is a Model XL-52 that I bought new on 6/5/06. The canopy is mounted on a Kubota B7500HSD with rigid ROPS.
Recently, I began having difficulty with the top staying square, that is, the right strut and right side of the top hung lower than the left strut and left side of the top. Also, the front clamp knob on the right side was loosening on its own. And, the whole canopy was vibrating enough to be noisy.
I took the top panel assembly off the roll bar bracket to look for the reason for these problems. I found eight (8) cracks through the metal of the top roll bar bracket. Three (3) cracks were in the rear vertical portion, four (4) were in the horizontal portion, and one (1) was in the right side plate portion. These are almost certainly fatigue cracks from bouncing around while mowing my pasture and meadow. The cracks were allowing the unwanted movement of the canopy.
A replacement kit with both brackets is available from Femco, Inc. in McPherson, KS for $131.25 plus $18.98 (Zip 67460 to Zip 48732) for a total of $150.23.
I decided to try to repair and possibly reinforce my existing bracket, before spending that much money. Luckily, I have a son with welding skills (although with limited access to equipment). My son finished filling in the cracks and adding a small angle iron reinforcement Saturday. Today was the first test. Three hours of mowing lawn with no problem. The canopy was rock steady. Hopefully this fix can stand up to the pasture.
If you have a TuffTop, you might want to check the top bracket periodically for cracking.
/ TuffTop Bracket Cracks #2
Kinda makes me want to inspect mine.
Can you post pics of the fix?
Sodamo - Here are photos of some of the cracks before repair.
The 1st photo shows the bottom/back.
The 2nd photo shows the right side plate.
The 3rd photo shows the bottom right side.
Sodama - Photos of the repaired bracket.
The 1st photo shows the front.
The 2nd photo shows the top from left side.
The 3rd photo shows the front right inside.
The added angle iron covered the original horizontal bolt holes and had to be drilled through to match. The angle iron also kept me from tightening the lock nuts, so I replaced the carraige bolts with hex head bolts, held the nuts stationary and tighted the bolts.
I hope this helps!
/ TuffTop Bracket Cracks #5
yes, thanks
WOW, that was cracked !!!!!
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
2017 Bobcat 418 (A60462)
2017 Bobcat 418...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
