B7200 HST Transmission shot-replaceable by novice?
/ B7200 HST Transmission shot-replaceable by novice? #1
ram042400
Utica, NY
Kubota B7200 HST-D
MY B7200 is now experiencing issues moving. Loader hydraulics are fine, will pick the front of the tractor up at idle with the B1640 loader. Can't get up the smallest inclines in high, especially after it is warmed up. I took it to my local dealer and pressure tested the transmission. The charge pump was good at 80lbs at half throttle. The forward direction port was only hitting 1800lbs upon initial forward momentum, and then dropping down to about 1000 while moving on level ground. Should be about 3800lbs I was told. We switched the reverse and forward relief valves w/ the same outcome. Anways, I've been told, I need a new tranny, as I guess, the most likely issue is that the internals are not sealing against some plate and maintaining a tight seal to build pressure.
I'm not anxious to pay the dealer's hourly shop rate, to swap the tranny's, and I am contemplating doing it myself. They were quoting me about three days of labor. I do have a good mechanical ability(I believe anyways), just wondering if this is doable w/ that, or if a specialist/knowledgeable person is actually necessary. I am a novice to hydraulics through. Assuming it to be pretty cut and dry as far as unbolting and separating and putting back together.
Does anybody know if I have to separate from the clutch area back or does it come out from the back, keeping the main frame area attached to the front of the tractor?
I just am not in the market right now for a newer tractor.
Any words of encouragement or advice? Thanks in advance,
Rick
/ B7200 HST Transmission shot-replaceable by novice? #2
sorry HST tranny is shot, haven't heard of many such problems.
This is a repair task I would not tackle although I do lots of my own mechanic work and have a shop.
I'd recommend getting a shop manual for the tractor, looking at the HST repair section and judging if you have the tools, skill and patience to do the work yourself.
/ B7200 HST Transmission shot-replaceable by novice? #3
A couple of things I see. First of all that pressure test should be done with the tractor blocked up against something, a moving reading tells you next to nothing. I would then check to make sure that it is not the clutch slipping, I have replaced far more clutches in that model machine than I have rebuilt HST's. The easiest way to see if the clutch is slipping is to drive the machine up to an immovable object like a tree or heavy post set in concrete. Put the machine in high gear at full throttle with the rear PTO engaged and lock the brakes. Have someone behind you watch the PTO shaft, when you push the HST pedal forward and the machine does not move, either the PTO shaft will continue spinning or it won't. If it stops spinning the clutch is slipping, if it still spins and the machine is not moving or spinning the tires then I would suspect the HST. This is when the pressure test should be done also. Maximum relief pressure occurs when the machine meets an immovable object, not on initial movement or when the machine is traveling.
As far as you being able to do the HST swap yourself, I think I would leave it to someone with more experience. Same with the clutch if that is what is needed instead. They are a little high on the time, 20-24 hrs is about what it should take to rebuild your HST not to R&R it. I would guess closer to 12 hrs for the R&R depending on the experience level of the repair facility. I could do the clutch in a day depending on any problems, I would quote 8-10 hrs.
Brian
/ B7200 HST Transmission shot-replaceable by novice? #4
I would say go for it, Rick. Brian's and John's suggestions are excellent:
get the manual and run those tests first.
If your HST is toast (due to low or dirty oil most likely), then you can buy
the important parts from Kubota. The hardest part about disassembly is
getting the tractor split in two. These units are much much simpler than
an auto trans on a car. I have fixed a few. If it is damaged, you will need
new valve plates, and possibly the pistons/cyl assemblies for the pump and
motor. The latter 2 assemblies are not sold piecemeal.
BTW, my B21's initial failure was probably a failed seal that spewed oil
all over the clutch.
Brian
I did put the tractor against a tree, in low and it will not break the tires free, even in 2wd. I had the transmission cover off when I did this, and I watched the "prop" shaft. It did not stop spinning, just got a lot of pump whine up front. When I brought it too a shop, they did check the free play on the clutch, which they said it was fine. And as far as pressure testing it, I was there when they broke out their service manual for the 7200, and did it according to specs. I too was hoping it was "just" a clutch issue. On those tranny's there is no break down to the individual internal parts, so I ordered up a whole new transmission, along w/ a service manual. Can anyone lead me to if the tractor has to be split at the clutch, or can I leave the clutch connected and disconnect the driveshaft and the prop shaft, and pull the tranny/rear end out the back of the frame. Thanks for the replies.
/ B7200 HST Transmission shot-replaceable by novice? #6
If you got the WSM from the dealer it will have all the info I think you are looking for and asking about. I had the WSM for my 7200 and it covered it in great detail especially the HST. By the way there are 2 screens in the hydraulic resiviour, I don't know if you have checked and cleaned them both? I believe one is for the tractor hydraulics and one is for the HST.
I say get the WSM look it over real good and then decide if you have the time, place and tools to do it.:thumbsup:
Good Luck !
/ B7200 HST Transmission shot-replaceable by novice? #7
How much is a clutch? I would look into replacing the clutch while I was in there (unless it looks like new). Might be a few hundred more, but cheaper than pulling things apart again in a few hundred hours to replace the clutch.
Aaron Z
/ B7200 HST Transmission shot-replaceable by novice? #8
To R&R the HST you can leave the clutch housing attached to the engine and just remove the HST, trans., and diff. together.
Brian
Brian
Thanks for the reply, that is what I was looking for. I have standard mechanic's tools, and hoping that will be adequate to tackle this one. Thanks again, it will be a few days before the parts come in.
Rick
/ B7200 HST Transmission shot-replaceable by novice? #10
My first question would be if you tried new filters, fluid, and cleaned all the strainers?
If you have not, I would at least try that before going to the effort to split the tractor.
/ B7200 HST Transmission shot-replaceable by novice? #11
I agree - I can not tell you how many times I looked for the hardest solution whenever it turned out to be really EZ. How many hours are on it and are you the original owner who took good care of it?
Yes, been through that. I had just purchased a 3 pt. backhoe for my tractor. When I brought it to the dealership for the hookup, they noticed that the hydraulics did not have much power. My loader was not able to lift up the front of the tractor, which they said it should be able to, and it had no digging ability. They first went through and cleaned the strainers, and the fluids, but to no avail. They then checked the pressure for the hydraulic pump, and they said it was about 900lbs. When they opened up the relief valve to check on things, there was a "split lock washer" in there for a shim, causing the spring to bind or stay tilted. They reshimmed it and pressure is up to where it should be. I think the said about 1750lbs. Anyways the hydraulics were like brand new. I can now pick up the front of the tractor at idle, where before w/o ballast on the back, it could not happen. When I brought the tractor home, w/ the backhoe on, it was then that I started to notice the transmission issues. I used the backhoe for some drainage issues, and that worked great, but my tractory appeared to have issues driving around, but I chalked it up to the added weight of the backhoe. But after I took off the backhoe, the driving issues were still there. And that is how I am where I am, w/ HST issues. I do plan on pulling the strainers, tomorrow, just to check on them, hoping that maybe something circulated around the system, w/ the increased pressure, that may be plugging them, BUT I am not optimistic. I figure that the tractor is 26 yrs old('84), I've owned since '07, hour meter reads 311, which I assume it has gone around at least once.
/ B7200 HST Transmission shot-replaceable by novice? #13
Interesting. Another field repair gone awry.....
Since you had the machine in to the mechanic, I assumed that the fluid
and filter issues had been checked.
Now, you have to do the HST field test as suggested by Brian: put the FEL
against a tree and try to go forward, watching the PTO shaft. Listen
for the HST relief valve to open.
/ B7200 HST Transmission shot-replaceable by novice? #14
That is one thing I wish my B8200 would have had, at least a 10,000 hour meter. I got it used with 425 hours on it; the dealer indicated it was true hours. I sold it with a little over 250 hours showing. So I believe it had 1250 total. But, there is no way to know. It's general condition when I bought it seemed reasonable for 425 hours.
Well cleaned the strainers, to no avail. The fluid is less than a week old along w/ the filter. Tried to go up a set of car ramps(tried is the key word as it did not happen) in high, while watching the shaft coming from the engine, and it kept spinning w/o slowing. Just a lot of whine from the pump. All that is left is to wait for the parts to come in. Funny thing, I was going to paint the body panels while I had it disassembled, and when I went to my neighborhood TSC, they have no Kubota Orange Paint. Apparently all the stores have a "stop sale" on the paint and it is going back to the warehouse. No Further Info available. Typical for me right now is that it is the only color that is going back. Trying to avoid the $12.00 that a dealer wants per can. Gotta love it.
/ B7200 HST Transmission shot-replaceable by novice? #16
For paint check out an auto supply store that stocks paint. Some of them can mix paint and put it in spray cans.:D
/ B7200 HST Transmission shot-replaceable by novice? #17
Rick
In the same boat
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2016 Isuzu Box Truck (A60352)
2016 Isuzu Box...
International 9200 (A61307)
International 9200...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2013 Keystone Laredo LA329RE13 37ft. T/A Fifth Wheel Travel Trailer (A59231)
2013 Keystone...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
