What should my rear ballast weigh ?
/ What should my rear ballast weigh ? #1
sailorman
Southeast La.
Kubota 2320
I 'm pretty much just tryin' to ballast FEL a bit when using for wood hauling, dirt, or road gravel. And I 'd like to stick with and average rate instead of adding or removing weight for a particular job as I 'm gonna use concrete for weight in one of those post cylinder things with a rod through it for lower links.
Stats : Kubota 2320 weight 1477 lbs., FEL with 48 " bucket 562 lbs.
Manual says a max of 660 lbs on lower links.
What do you think would be a weight ? As a side note, I think it will be cheap to do so I might make a few different weights for different jobs.
/ What should my rear ballast weigh ? #2
IMHO, it should be the maximum or close to it the 3PH can lift.
Multiple weights is a waste of time...suppose you are moving some mulch, then you see a large rock you need to move-you gonna go change rear weights?
Thanks Kenny, point taken and a good one for me to consider. But, if I 'm haulin' mulch I doubt I 'd have the weight on at all.
I know its been discussed before, but I couldn 't find it with search. Ya got any idea what hardened quikrete weighs by volume ?
/ What should my rear ballast weigh ? #4
My understanding is a bag of concrete will weigh whatever the bag weighs plus a bit more. But the approximate weight is the dry bag: 80 lb bag will weigh approximately 80 pounds dried. The water added just causes a chemical reaction with the cement and eventually evaporates.
Maybe an expert on the subject can add more detail.
Makes sense to me and makes me feel a bit stupid ( not the first time :laughing: ) .The water should be evaporated so 80 # 's is 80 # 's. When I decide what weight I want, it should be easy to calculate bags and volume of container. Thanks !!
/ What should my rear ballast weigh ? #6
Concrete will normally run about 148 lbs per cubic foot
/ What should my rear ballast weigh ? #7
The water and portland cement react together to form a hydrate, which is
your glue that holds the aggregates together. It does not dry. You
may lose some water by evaporation off the surface of wet concrete, but
most of the water you add is consumed in the chemical reaction. So an
80# bag would make maybe 90# of concrete, I would guess.
I use 150#/cf for cured concrete as an approximate weight, but it can
be a little less for small aggregates, and a bit more for large aggregates.
/ What should my rear ballast weigh ? #8
Yep, rear weight , IMHO, needs to be sufficient to allow you to have max weight in FEL and maintain safe attitude (no wheelies) while traversing uneven but reasonably safe ground at reasonable/safe speed.
For me, I added the appropriate weight to my box blade (a little trial and error involved) and now leave the weighted box blade on the rear almost all the time. It comes off only when a different 3ph implement is required.
Frequently, if a different (lighter) rear implement is mounted, I am reminded of the need for proper rear weight by unbalanced conditions as I encounter/attempt the unplanned task that puts very significant weight on the front.
/ What should my rear ballast weigh ? #9
You got some excellent responses here.
If you want an "official" answer, your tractor and loader manuals should have a page or chart with ballasting requirements and weights.
As far as what to use....pretty much anything heavy enough. I prefer a factory or homebuilt ballast box since it keeps the weight nice and compact (less to worry about when you're backing up).
/ What should my rear ballast weigh ? #10
You NEED rear ballast when anything is in the bucket. If not all that weight is carried by the front axle. Mulch is heavier that you think.
Really great info. comin' from ya 'll. I 'm gonna change my approach based on advise and what I 've been able to determine from my manuals. Manuals : 1 ) no specific ballast weight is reccomended for loader except the max weight off 660 # on lower links of 3ph. Just says may vary by job. 2) various implement weights are suggest if used for ballast. 3) filled tires are suggested also, but that 's a little too permanent for my purposes.
New approach : 1 ) continue to save bucks for needed box blade and use it with added weight when needed. My bush hog weighs more, but will hinder manuvering in tight spaces. 2) us my carryall rig with scrap weight while saving bucks. 3) experment with different weights until I learn the sweet spots for jobs.
Anything I 'm over looking in this approach ?
/ What should my rear ballast weigh ? #12
I would first question why your manual says 660lbs max.
Kubota lists the 3PH specs @ ~1300lbs at pins and ~1000lbs @ 24" back. Allthough I doubt you could keep the front end down without the loader on.
Idealy you want enough ballast out back that the loader cannot lift the back of the tractor. This is easy to determin by trying to lift something that's too heavy. Like an old vehichle or geting the edge under a large rock. If the hydraulic relief opens and the rears are still on the ground, you have enough weight.
For your size tractor, I think somewhere between 500 and 600 lbs should do the trick. 60lb bags of cement make 1/2 cu ft. And cured it weighs 150 per cu ft as already mentioned. (yes a lot of water stays behind. Concrete has a really high moisture content, kinda like green wood).
So you need about 4 cu ft of concrete. Thats only 8 bags which menards around here usually has 4 for $10. So for $20 you have yourself a nice counterweight.
On a side note, I am not sure I quite understand how you plan on using the cardboard tubes. If you plan on laying it on it's side, I'd recomend aginst it. It will like to roll around and not stay in one place from time to time. A 600lb cylinder of concrete rolling your lawn all by itself probabally wouldn't be good.
If you have access, and maybe save a little money (them tubes are $$$) get a plastic 55gal drum. They are about 22" diameter so they will fit between the 3ph arms. 4cu ft = 30 gallons. So cut the barrel off @ 18" up from the bottom and drill holes in the side, and shove the lift arm through. May also be a good Idea to weld an upright to tie into the toplink, if you so choose. And I'd wrap the lift arm with some old wire/fencing if you got any to get rid of.
Here is a link like what I am describing. Just shorten the barrel accordingly.http://www.tractorbynet.com/forums/build-yourself/164889-simple-three-point-counterweight.html
Nice info LD and thanks for taking the time to reply. Good suggest on using the drum. I 'll definitely look into that. So far I haven 't been able to locate drums in my area.
Your answer has brought up more questions that follow and I hope you might find the time to answer.
Quoting my manual, Lower link end max. loading weight 660 lbs. Now if I misread and it means per arm then it would be 1320 lbs which is close to what you say. Is that what I did ?
Yes, I did plan on tube on side. But, I don 't understand what you mean by rolling my lawn. Do you mean if weight contacts lawn it would roll ? If so, I would have it raised up not on the ground.
Could ya give me a little more info on that lifting an old vehicle thing ? Do you mean I should have ballast on, try and lift the vehicle, and see if the relief valve kicks in so tractor rear stays on ground ? And is the relief valve related to the term breakout force. Is that the weight of a lifted object that will cause the relief valve to function to prevent rear end lift and damage to loader or tractor ?
/ What should my rear ballast weigh ? #14
The rolling the lawn was kinda a joke. Meaning that if you try to unhook it on unlevel ground, it may get away from you. Like parking your tractor on a hill in neutral with no brakes set:confused2:
As far as what your manual says about 660lbs I don't know for sure. It depends on just how it is worded. But I find it odd if the max is 660 and kubota lists the spec @ a little over 1300lbs rear lift.
As to what I was saying about lifting a car and the relief and all that:
Idealy, for saftey, you don't want your loader to be strong enough to lift the back tires in the air. The only way to do that on these small light machines is with rear ballast. Your hydraulic system will only develop about 2500psi of pressure(I don't know the exact spec). With no weight on the rear, that is enough force to lift the back of the tractor in the air. That transfers the entire weight of the loader, tractor, and whatever you are lifting onto the fron axles. Thats just too much stress on them. The more weight you have out back, the less weight that gets transfered to the front, as more of it stays on the rear.
You mentioned you had a carry all. Assuming it weighs about 100lbs, load it up with about 500lbs of whatever you have, and try to lift something with the FEL that you know is too heavy to lift. If the back tires raise into the air, you know you need more weight. If the back tires stay down, and the whatever you are trying to lift doesn't budge, that means your loader relief valve is kicking in and you have enough ballast. But also keep in mind that 500lbs of ballast hanging back about 24" on a carryall will do more than 500lbs right at the pins. It's a leverage thing.
Now that is very clear to me. Over looked the roller joke. Wish I hadn 't 'cause I can just envision the pandemonium that would cause now that you pointed it out ! Fortunately I 'm a flat lander.
My carry all is customized with a platform and I would be sure to stack weight as close to the life pins as possible to dampen leverage situation. I got the perfect junk trunk in yard to lift ( the red neck in me ) .
And the relief valve prevent loader damage while running this test ?
Thanks a billion !!
/ What should my rear ballast weigh ? #16
You shouldn't be able to do any damage at all. We have all tried to lift things that our trators wouldn't. Like digging out stimps, or trying to pry out rocks, etc. Only one of 2 things should happen if you try to lift something too heavy.
1. Your rears will lift
2. The relief will bleed pressure.
There should be nothing to damage on the loader. If something isnt structurally strong enough to handle the 2500psi the tractor makes, then kubota would have designed it differently.
1. Your rears will lift.
:laughing: Did that one right out of the gate. Scared the you not what out of me. Let that loader down real quick :laughing: .
Thanks for the help :thumbsup:
/ What should my rear ballast weigh ? #18
A clue that works for me in determining total weight needed in rear....
Rule 1..... weight should be sufficient (as mentioned before) to keep rear wheels firmly on ground when FEL hydraulic relief valve is open because weight limit is reached.
Rule 2......with almost max weight on FEL (for me this is 2800 lbs which I can raise to a height of about 1.5 foot before relief valve opens), be able to drive at reasonable and safe speed over reasonable ground without rocking back and forth significantly. Point is, if you have barely sufficient weight to keep rear wheels on ground while parked, then when driving over necessary irregularities the nose will dip and you will feel the rears lighten up or actually leave ground contact. If this happens, continue to add rear weight until the entire tractor feels "solid on the ground" while fully FEL loaded and driving reasonably. I know when I have the proper balance...it just "feels" right while driving. Don't worry about putting too much weight on the rear, all tractors I know of can lift far more weight in the rear than they can in the FEL.
/ What should my rear ballast weigh ? #19
Adding ballast weight to the 3PH is just about the most unprofessioal thing I have ever heard of. In time it will do damage to the dirveline and bearings. In the tire ballast is the answer.Tire ballast put the wieght on the ground not on the bearings and driveline. You 3PH is always open of use.
/ What should my rear ballast weigh ? #20
You are absolutly crazy. Who cares what's "professional" and whats not. We are just home owners that have small tractors to maintain our property.
Hey maybe he should just leace his tractor sit in the garage and never use it at all. Because that would put hours on it and wear things out eventually.
Tire ballast is NOT the answer on SCUT and CUT tractors. It will help but the tires just arent big enough to give enough ballast. And once in, it's permanent and many on here use their CUT of SCUT to mow their lawn, where the weight is not wanted. If we were talking a farm tractor that only sees field work, then that would be a different story.
The OP could do as you suggest and load his tires and not use any rear ballast as it is "umprofessinal". And when he goes to move a full bucket of clay, or gravel, or whatever, and the rears are in the air, and all the weight is on the front axle, doesn't that wear things out a little quicker than say......putting 600lbs on a 3ph designed for 1300lbs??????:confused2:
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
1988 23ft Stealth Craft Boat w 22ft Boat Trailer (A61574)
1988 23ft Stealth...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
