Oil & Fuel Fuel Filter Change BX2230
   / Fuel Filter Change BX2230 #1
pondrosa
Can anyone give me instructions on changing both fuel filters on a bx2230?
The shut off solenoid should keep fuel from leaking when I change the one in the engine compartment
The filter between the tank and the solenoid is the one I'm worried about:cool:
Tom
   / Fuel Filter Change BX2230 #3
Use vice grips to crimp the fuel line.
   / Fuel Filter Change BX2230 #4
Tom
Easy, remove filter and install new one..Do not bother crimping line. You will lose about 4 oz fuel...It will start right up..
   / Fuel Filter Change BX2230 #5
Tom
The fuel solenoid will not keep the fuel from leaking. It only energizes for a few seconds to shut down the fuel rack in the pump to kill the engine.
David Kb7uns
   / Fuel Filter Change BX2230 #6
How do you get to the filter that is close to the fuel tank?
   / Fuel Filter Change BX2230 #7
There are 2 filters. One up by the injector pump, the other just inline ahead of the electric pump. To get to the one ahead of the pump, pull off your mower if you have one, and crawl underneath. There is no filter up by the tank itself.
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
