new Kubota operating Question
   / new Kubota operating Question #21
On my small tractors, I like weights, but on the bigger ones I always add fluid.
   / new Kubota operating Question #22
I am curious why? I don't think there is anything wrong with wheel weights, I just haven't seen what the advantage is over using liquid ballast. Liquid ballast is sure cheaper. If you have a need to remove the weight do to your applications or your setting is prone to tire punctures, I understand. Other wise what is the advantage?
MarkV
   / new Kubota operating Question #23
MarkV
Couple of factors really.
1. I have lost a lot of fluid over the years due to punctures.
2. I have to call a service truck for the big tractors, but I can remove the little ones and take them to the shop or plug them myself.
I go with fluid in the bigger tractors due to the cost and I mow on a lot of inclines and fluid "seems" to lower COG and help them stick to the ground better.
   / new Kubota operating Question #24
Well I sure understand that! In my case I have had one of my tractors for 10 years with non-toxic anti-freeze and water in the rears and no leaks. I live in the South so I did it in the drive for little money and little worry of freeze issues. It sure did help with stability in the N. Georgia mountains where I originally bought it to use. We don't have the Locus thorns or sharp rock some on the forum have so punctures haven't been a problem for me. Wheel weights were just so much more expensive I couldn't see the advantage. Guess it is a bit like land, Location, Location,Location, is what you have to look at to decide what is best for you. Inter-net experience is valuable but not necessarily universal. You still have to see what is best in your area.
Thanks,
MarkV
   / new Kubota operating Question #25
Thanks,
MarkV
Yep, location and use sure do change the demands placed on equipment. Many years ago when we were cleaning out a patch of woods, we didn't put weights or fluid in, but just put a lot of tire sealer in due to the thorns. A couple years later, we put new tires on when things got under control, but still have an occasional problem on one of our farms. Stobs have also taken a couple out and one cultivator foot many years ago.
   / new Kubota operating Question #26
I have a B7800 with R4 tires that came filled from the dealer; they always fill the tires on a tractor with a FEL. I normally don't have anything on the back of the tractor when using the FEL, and don't have any problems. I also have a 45HP John Deere tractor that has filled R4 tires that were almost worn out when I bought the tractor 18 years ago. I'm still using it (mainly for mowing) and have never had a leak, air or fluid. I think the fluid must plug small leaks kinda like slime does.
Update on the water in tires, I got a hold of the sales manager and he said they always add water to the rear tires with a loader on it. So the delivery guy was wrong
   / new Kubota operating Question #28
Not sure where you are located so it may not be important. I am guessing when the dealer said they have loaded the tires with liquid they have done it with the appropriate liquid for your area. I sure would not want to have straight water in my tires if I lived in Maine. :confused2::confused2:
MarkV
   / new Kubota operating Question #29
How can you tell if you have fluid-filled tires?
   / new Kubota operating Question #30
SmallTime
Stop your tractor with your rear tire to the 3 o clock position. Take your valve cap off and pretend to let out 2 or 3 lbs of "air" if pure liquid comes out, you have filled tires.
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
TRUCKING INFO (A50774)
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
2011 Cadillac SRX SUV (A50324)
2011 Cadillac SRX...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
