new Kubota operating Question
   / new Kubota operating Question #1
4t9ers
Hello, I got my new B2920 today. I was told be the delivery guy that I should always have the rear cutter on with the loader because it will balance the tractor out. I found tonight it makes it tough to get into tight places with the cutter on. Any thoughts?
Thanks
Jim
   / new Kubota operating Question #2
Are your rear tires loaded with liquid of some type? If so, you can do light tasks without the cutter on. The cutter will be bulky swinging around off the rear while you do other tasks. Its not a neccesity to always be on. If your doing heavy FEL work, digging, etc your tractor will operate better with weight on the rear, be safer, and feel more stable.
   / new Kubota operating Question #3
If I am doing anything other than very light FEL work, I like to have some kind of heavy weight on my 3 point. One option is a mower, they are heavy, but as you have noticed, they are big. Another option I use is a pulverizer, this is heavy, but not very large. Of course a grader box or blade is good, not always that heavy, but if I have the FEL on, I am usually doing some grading also. Best option to maximize 3 point wieght is a ballast box, either purchased or home made. The Grand L series box is 1000 pounds with dry sand. Philip.
   / new Kubota operating Question #4
I don't intend to put money toward a ballast box. I'd rather it go toward something useful. People like box blades. They don't project like a mower, aren't as wide, yet provide some substantial counter weight. I have an RFM and cannot imagine using it for FEL work. I have a 3 pt bar hitch, on which I can put a few hundred pounds of old work out weights. That is only so much help.
Only weight on your 3 pt will lever FEL weight off the front axle, to save wear and tear. Wheel weights or loading tires cannot do that.
   / new Kubota operating Question #5
For FEL work I have my box blade on the 3 pt. Less bulk than the mower. Suuficient for my (balance) needs. It's a very usefull tool when needed as well and not too expensive - $325 new. I've definitely got my money's worth out of it.
   / new Kubota operating Question #6
Can't say enough for loading the tires...Keeps the 3 point free for use... skidding logs and then handleing with the bucket/grapple etc....
   / new Kubota operating Question #7
Like General Lee, I have done lite and even not so lite loader work with just loaded tires, but recommend added weight of some type, BB etc. when doing anything other than lite work as it makes it easier and safer.
   / new Kubota operating Question #8
It is pretty easy to make a counter weight inexpensively. A plastic garbage can, a draw bar inserted through it, eye bolts for a top link hook-up and readi mix cement. A search on the forum will show some innovative modifications like tool holders and receiver hitches added to the weight.
MarkV
   / new Kubota operating Question #9
There are other implements that don't project out back so far, as others have said. If you continue to use the mower for counterweight for a while, be careful about climbing a dirt pile, etc. with it. Because it sticks out a long ways, you can bind up the top link and do some damage if you aren't careful.
   / new Kubota operating Question #10
I built a counterweight, 55 gal drum $9. tractor supply drawbar $26. reciever hitch $9 (just because I wanted one) concrete about $30. The steel 4inch angle iron and the rebar was scrap lying around, if you had to buy it, probably about 20 bucks. Of course I have a welder. but as you can see you can build one pretty cheap. mine was a total of about 750 Lbs when finished
James K0UA
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
RoGator 844 sprayer (A50490)
RoGator 844...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
