Loader Lightweight pallet forks for 200X & 200CX loader
   / Lightweight pallet forks for 200X & 200CX loader #12
Thanks everyone! I will definitely be making this available to all. To get the ball rolling, here are the resources for the kit:
1- The pallet forks and rails are $229 and come from ATVXpress on eBay with free shipping [FYI, ~$130 of that figure is the shipping]
2- The JD pins are W47211 ($16.50 ea) and the hooks are W43359 ($12.59 ea).
3- 1.5" square x .125" steel tubing (~$15). I can supply this if needed.
4- The 6 engineered and waterjet cut plates supplied by me, along with assembly instructions for the build. (TBD)
The waterjet cut plates aren't cheap but the overall cost for the whole kit is still substantially less than anything available on the market, especially when you consider the very light weight of the design which is really the most important goal for JD tractors using the 200X or 200CX loaders.
I'll let you know as soon as I get the figures. It should be in the next couple of days.
The unique items you have are:
1) CAD plans
2) engineered and waterjet cut plates
In volume, you might find the waterjet plates really reduce in cost. Also in volume you might find it cheaper to create your own hook & pins to add into your DIY kits. Just thinking that you could offer two DIY kits. One might contain just your CAD plans, materials list, assembly instructions, waterjet plates, hook and pins. The other DIY kit might contain all materials. Finally a fully built and painted finished product. I would expect the base DIY kit to be your highest seller. It would be neat to see what people on this list would create using your kit as their base.
What do others think?
Sweet looking, would this design work on my 300Cx?
Hi bf,
Yes, the design will almost work but the vertical distance between the hooks and pins are a little farther apart on the 300xx vs the 200xx. I don't know that distance off-hand but if I could get it, I'd be happy to create the design. Another aspect to verify is the width of the fork slider rails vs the width of the loader itself. Lastly, I'd also want to know what the highest lifting capacity of the 300xx loader could be on the most powerful tractor it goes onto. I wouldn't want to exceed the 2300 lbs capability of the forks.
1) CAD plans
I'm not sure I totally agree about making the hooks and pins. Possibly the pins, but probably not the hooks. For the short money, I like the OEM JD bits. But that's just me.
Similar to what you are saying, I'm also considering the possibility of shipping a tacked up frame which would just need to be finish welded and have the fork slider rails stitched on, then painted (all of the easy work). That way folks wouldn't have to pay for shipping the 150lb forks & rails twice. They buy the forks & rails and my frame and that's it. We'll see.
I am also very curious to see what great things could stem from the base frame design with the ingenious people who peruse these forums. It is what I look forward to the most. Glad you mentioned it.
   / Lightweight pallet forks for 200X & 200CX loader #15
Hi bf,
Just a note Chris: The spacing is the same...it only changes in the big 500 series loaders.
   / Lightweight pallet forks for 200X & 200CX loader #16
Just another note: The "hooks" can be made frome 1 1/2" angle iron, they do not need to be formed like the JD ones. I can post examples later when I get home.
Thanks Kenny, I could swear I looked at some forks with dual pins and being advertised as compatible for both the 200 & 300 series loaders. I just assumed the dual pins meant one for the 200 and one for the 300's. Glad to have you on staff!
   / Lightweight pallet forks for 200X & 200CX loader #18
I like the idea of a ''tacked up frame''. Most of us are already equip to finish the job, or knows someone who can do the job. Either way, as soon as you have something figured out, please ''pm me'' Thanks. Henri
   / Lightweight pallet forks for 200X & 200CX loader #19
Add me to your growing sales order stack! I've been looking for something useable to pick up debris (logs, brush, etc) to aid in clearing some woods, but nothing I've found has been reasonable. Until now!
Let me also add an idea to your list of products - a skid plate for the bottom of the 2305 tractor! I've wanted something that can hook onto the mower deck mounts, yet stay underneath the machine without taking up the little available clearance. I don't like taking off the mower deck to work for fear of breaking the tranny oil filter or fan blades. But I don't like leaving the deck on for it's serious lack of ground clearance. Something easily removable that can protect those items is outside of my design and fabrication skills. But seems within reach for you... Hint, hint...
   / Lightweight pallet forks for 200X & 200CX loader #20
As promised, pictures of the homemade hooks below. It may be 1 1/4" angle though and not 1 1/2", but you will get the idea. Since the hooks don't rotate, but rather just hang this a cost effective solution although it may not look as pretty.
The pictures are small since I bootlegged them form other posts.
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55852)
40ft T/A Gooseneck...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
Galvanized steel fence (A53424)
Galvanized steel...
