LX 280 motor just blew
   / LX 280 motor just blew #1
silverbeast
Hey guys, i got my mower out today and out it blew up with less than 200 hrs on it. oil level was fine and the last time i used it it would bog down and puff some smoke when i engaged the pto. I thought i had a bearing locking up on the deck but i guess it was internal. :( Now what would you guys do about replacing it. Go to the dealership and buy one or buy a new motor from northern tool? It has the 18 HP v twin....can i go bigger. If i can i would like a little larger motor. Thanks for any help.
   / LX 280 motor just blew #2
Tough call. What engine originally came in your mower? What condition is the rest of the tractor in?
Can you afford a replacement instead of repairing your current ride?
The rest of the mower is in great shape. I can afford to buy a replacement but there is no need since the mower has less than 200 hrs on it. It has the 18hpv-twin.
   / LX 280 motor just blew #4
The LX280 had the twin-cylinder, air-cooled Kawasaki engine. This is normally an extremely reliable engine. Can you provide more detail about the problem? Did something literally blow out of the engine or is it just not running right?
   / LX 280 motor just blew #5
Any idea what is actually wrong? "Blew up" doesn't really help much. :)
Well it started off bogging down when i would engage the pto and it would puff a little black smoke. I mowed half the yard and put it up. I thought the deck had a bearing going bad and was causing the extra strain when i was mowing. Got it out to finish the yard and when my wife started it up white smoke started pouring out and it wont stay running. I mean enough white smoke to choke all the bugs to death clear in the next county. Im thinking blowed head gasket but the way it was bogging down im wondering if it didnt spin a bearing on the crank. Either way it blew up,lol.
   / LX 280 motor just blew #7
Sounds like a hole in the piston. did you hear a knocking?pull the moter down if its a piston replacing it is easy.
Falcon
   / LX 280 motor just blew #8
I think the odds are very high that this engine just needs the attention of a good mechanic.
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
