3720 cab vs open air
/ 3720 cab vs open air #21
WOW Great feedback.. I searched on the JD site for the overall height of the 3720 with cab, Does anyone have that measurment? My shelter is exactly 8 feet tall. Hope that is tall enough.
I'm sure the 3720 cab with smaller R4 tires will fit thru a 90" door (7.5') but with very little room to spare. That is what I have. For 8' door height, the larger R4's and R1's are probably close. Hopefully someone will answer for the larger tires.
/ 3720 cab vs open air #22
What about we the change the title from 'cab vs open air' to 'cab vs second honeymoon vacation'. Happy wife, happy life. :D OK if I had a cab, I'd be happy to. But eventually you have to come out of the cab and go inside. :laughing:
Loool, I had to sacrifice the front loader for my wife to have the cab, option which she really wanted.
/ 3720 cab vs open air #23
I don't know the cab but this is the info Deere sent me on the small and large R4 tires for the open 3x20 series:
small R4s = 91.8"
Large R4s = 92.5"
Rob
/ 3720 cab vs open air #24
Well you can add the wheel spacers to widen your track but I would consider a 4320 cab too. Not much more money and alot more tractor. More stable with a wider stance I am very satisfied with the 4520 cab.
Agreed.... Do I wish I had a 4x20 Cab? Kinda Sorta....alot of things factored into my decision...
A) Price difference between a 3x and 4x was stupid for me...they pratically paid me to drive the 3520 Cab they had on the lot away :laughing:. Long story, not really on topic for this post.
B) I only have 2 acres...pretty sure my 3520 is more then enough considering I also have a F935 to handle mowing.
C) Height...the fact a 3x20 cab with Large R4's easily fits in a 8' door was a plus.
IMO, the lack of stabilty of these machines is grossly exaggerated, yes, you are not driving a Formula 1 car, but you are also not driving a unicyle. My feeling on the subject is that it feels worse then it actually looks. When I first got my 3520 I thought to myself, what the heck did I just buy, but a couple years later I am very comfortable with what it can and cant do. I dont think its any worse then some other colored CUT's I've driven.
/ 3720 cab vs open air #25
Dave,
Well I am certainly no expert on the 3X20 machines as I only tried the 3720 cab tractor on the dealers lot. Tried out a 4720 and the 4520 next and decided on the 4520 and ordered it. Since I had some implements for the 110tlb that were sized just right for the 4X20 machines it was a no brainer. At the time when looking at the 3720 I couldn't picture it handling the larger boxblade or MX6 I already had. I could picture myself having to remove the hoe from the 110 for the higher draft tools and buying a new dedicated tractor was the whole purpose of this.
My open air tractor, the 820 with canopy weighs about 4000 lbs before ballasting so it works well with the existing implements too. My point being that it is important to make sure the big picture works for you. From the tasks that need to be done, time available to do the work, implements available that fit the jobs and finally a tractor that fits these jobs. If I didn't perform custom work I could easily get by without a tractor but I ain't doing that.:D
/ 3720 cab vs open air #26
We should make that sentence a sticky here in the buying forum. :thumbsup: There is a reason all MFG's offer various sizes, tires, hp's, features, etc... What works for me might not work for you or vice versa.
I've said it before..in the perfect world, MY personal perfect machine would have been this:
-Deere 110 with Green Paint, I'll call it the 1120 LOL
-Factory Cab identical to the 3x20/4x20
-Deluxe Interior like the 3x20/4x20 Machines
-3pt Hitch (no Hoe for me)
If I coulda gotten that, man...that would be the perfect machine.
/ 3720 cab vs open air #27
That' right Steve, it's only rated for the MX5 cutter.
Rob
/ 3720 cab vs open air #28
Rob
We can debate this further, But I personally would'nt buy a MX5 for my 3520...it would be an MX6 or nothing at all.
We've had this discussion on various other attachments (Snowblowers, Mowers, BB's, etc) and some people like to undersize attachments. I think a 35/3720 is a 6' machine and I wont buy anything smaller then 6' for it. Heck, I've put many hours on our L2900 GST with a 6' Bush Hog and my 3520 has way more grunt then the 2900. I have zero doubt in my mind that a 6' bush hog of any color is what belongs behind a 35/3720.
/ 3720 cab vs open air #29
I think that the MX6 is not rated for the 3x20's because of its weight. I have an MX5 on my 3720 and you have to have the loader on the front when you lift it. There is a lot of weight a long way behind the lift points of the tractor and that might push the edge of what Deere will recommend. If your careful, you could use a 6 foot cutter all day as power on the 35 and 3720 should not be an issue. Its picking the unit up and transporting it.
I ordered a MX6 for the 4520 I have on order and I assume that will be small for that tractor, although it will still be heavy.... Its 1,000 pounds.....
/ 3720 cab vs open air #30
Gotcha.....if I were buying a RC, I'd get the SQ172 @ 764lbs. But that does make sense.
Still..if I had access to a MX6 to test, I'd like to try it...just to say...
/ 3720 cab vs open air #31
I understand the argument for a basic 6 foot bushhog in the 3000 series but I don't get the focus on the MX6 or medium duty bushhogs. So many people I know just cut grass with their hogs, or if they need to clear brush, after the initial brush clearing to create pasture, any hog with 1" capacity is fine. The MX6 seems like more weight, cutting capacity and expense than most people need on an ongoing basis.
/ 3720 cab vs open air #32
My MX6 will be here prior to my tractor. I will test it for you if you want...:laughing:
I doubt anything with it will be an issue other than picking the whole RC up and traveling any distance. At 5mph plus with the RC in the air, any bump could be its last, before you flop.:confused2:
I think a lot of people like to buy deere equipment? and some want the best?
I do a ton of cutting around our farm fields and I never know what I might come accross. People throw things in the worst spots, so I want a cutter that will be bullet proof. I have tore up our cheaper cutters ina few seasons and I like the reliability of the medium duty cutter. If it was just for maintaining the field behind my house, it would be way overkill!
/ 3720 cab vs open air #33
I wont be the one to stop you! :cool:
While I understand the need for a mine clearing mower, if I were to buy a green one (Still prefer the Bush Hog one I mentioned earlier...best blend of performance/heavy duty/cost) it would be the Frontier 2072, I'd say that would be right at home behind any of the 3x20's....and for most of us, more then enough cutter.
I guess I just dont understand where in the marketplace the MX6 fits...yeah it sells, but why?....because its better then your neighbors? Any mower that tough in that size really makes me scratch my head. If I had that much mowing/that large of brush to mow, I'd go grab the Batwing and 100+ horseys...
/ 3720 cab vs open air #34
You may be right Dave, I'll have a better sense when my tractor comes in. I do know that the 2720 ran the Woods 60 cutter without any problems but this is much lighter than the MX stuff and the 3x20 series is about 1000 lbs heavier than the 2 series.
Rob
/ 3720 cab vs open air #35
I have never looked at the Frontier 2072. I have seen the SQ1072 that you speak of. IIRC, its not dual layer constuction like the MX5-6. I cut small sections around fields and ditches and I do not stop if there is a branch down in front of me. I make mulch...LOL...
The MX-5 fell in my lap for a great price when I bought the 3720, and my dealer is trading in my MX-5 and giving me a brand new MX-6 for 250.00 dollars. Why look at anything else with that deal?
Plus, a larger tractor would have a hard time not running over the crops in the field. I can usually not do any damage to the crops with smaller tractors.
/ 3720 cab vs open air #36
I'd like to know what it is that people are running over to tear up their light-duty bushhogs. In 30 years my dad went through exactly two basic 5 foot bushhogs of the King Kutter variety. As a boy I'd hear him out there bushhogging, sometimes making a huge racket as he ran over something large. The worst outcome of this was an occasional shorn shearbolt. In the 3 years since his death we have never even blown a shearbolt with the 3320 / 5 footer King Kutter and that's with three different people doing the mowing.
The best I can sum this up based on my family's experience is that a 6 footer sure would have been nice, but not a stronger gearbox or thicker endplate.
/ 3720 cab vs open air #37
MSmud,
Either have we but I guess some folks take these things in the woods to trail blaze or something. All we ever do is our overgrown fields. We hit a rock once and a while but not much happens.
Rob
/ 3720 cab vs open air #38
From JD brochure:
3x20 height with cab and R1 tires is 89.4"
4x20 heigth with cab and R1 tires is 95.4"
R4 tires will be a little shorter with both.
/ 3720 cab vs open air #39
We run an MX6 on our 3720 and it handels it perfectly fine. I actually am glad since when on hills the extra width helps with stability and when doing loader work it helps with ballast. I've mowed some steep inclines with the MX6 and the fact that it sticks out so far helps a lot when i need to mow stuff to steep to back into. These hills in the pictures i just recently mowed were steep but backing up and down them made it posible to mow the whole thing. IMHO, I too believe that the 3720 can pull and or run 6' implements. In some cases, yeah, an MX5 would be a better choice but the MX6 works for our needs. cab wise, I've never heard of anyone who said they wished they hadnt gotten a cab because those who do have them love them.:thumbsup:
/ 3720 cab vs open air #40
I had the measurements but threw them away :eek:
The measurements will vary depending on which tire you have (Ag, R4's, Turf). You should be able to get this information from a John Deere dealer, that's where I got them.
The measurements will be the same on a 3320, 3520, or 3720.
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
429872 (A61166)
429872 (A61166)
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
