King Kutter information needed
/ King Kutter information needed #1
Mahindracub
Looking for info on a king kutter 1260 rotary cutter a guy has one for sale and I have to travel to see it so just trying to do some homework. This is supposed to be a heavy duty model, anybody have any info or know a website to try.
Thanks in advance for your help.
/ King Kutter information needed #2
Try King Kutter Incorporated
I tried there but only found the newer models listed.
/ King Kutter information needed #4
what specifically are you trying to find out. there isn't much to a rotary cutter.
gearbox, deck, blade carrier, blades and tailwheel.
soudnguy
/ King Kutter information needed #5
If you just want to know if King Kutter is a good machine.
they are pretty good units. I have used a few and never had a problem. the heavy ones are pretty hd.
/ King Kutter information needed #6
I have a 5 foot King Kutter brush mower and would get another tomorrrow if I needed one. It does a great job and is heavy enoungh for general use.
I just want to confirm that thisis a HD unit, what HP gear box, is the frame made of heavier gage steel. I have some havy stuff to clear and need a strong unit.
/ King Kutter information needed #8
I think the 60 in the model number 1260 stands for a 60hp gearbox. The standard gearbox is rated at 40hp. That might get you heavier metal as well but I am not sure. If the 12 is for steel gage then that's pretty standard. 10 or 8 would be considered HD.
/ King Kutter information needed #9
EverythingAttachments sells king cutters and has a bunch of info on them as well as prices that way you can look up your model compare it to others and see if you are getting a good deal.
/ King Kutter information needed #10
I have the 'regular' 40hp 5' king kutter mower and it's been a good mower for 10ys now.. plenty for pasture mowing and some thickets and the occasionaly ant mount and burried lumber discovery.
soundguy
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
2011 Bobcat T650 Compact Track Loader (A64047)
2011 Bobcat T650...
JCT Skid Steer Tree Puller (A64047)
JCT Skid Steer...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
