Backhoe 4672a on a B7610 help
   / 4672a on a B7610 help #1
hdfattboy2001
Hey guys, Just picked up a backhoe for our 7610, It was a demo, so it was all assembled buy it was previously on a 3400 larger machine.... We wrestled to get the unit on the tractor and I'm not sure we have all the top link and lower frame adjusted properly... Anyone have any pictures of their's setup,? The only way we could get the 3 point hitch arms to hook up, was to go OVER the lower main frame, reading the hookup information it says they go under it? I have to call the dealer tomorrow and get the paperwork on the unit because he forgot to give it to me....
Thanks for any help you can give.....
We did get the stronger top link bracket installed, and I have the frame support kit to strengthen the undercarraige...
Brad
   / 4672a on a B7610 help #2
I have a BH4690B on a B2910 ..... but I'm afraid I don't have any pics of it handy .....
It can be a bear to mount ...... if you will be storing it inside on a concrete floor, consider making a backhoe dolly for it at some point in the future ..... that will ease hooking it considerably ..... plus it will allow you to move it around if need be .....
On the mounting, one thing I can tell ya that I have found on my 4690B is that when I mount mine I will pull the two pins on the vertical lift arms/linkage for the tractor's 3PH lower arms ....
You should see if he will provide a little service after the sale so to speak - and send someone out and show you how to mount and remove it ..... :thumbsup:
Yeah - you absolutely want that stuff installed .....
You betcha ! :D
Thanks guys,I got the manual from the dealer today and it cleared up a lot of my questions. I now have the heavy duty top link installed, the lower frame support kit, and the hoe.....Looking forward to starting my drain tile project with it, the little bit I played with it makes me feel like I will be happy with it.
Thanks again,
Brad
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Ford 8340 (A53317)
Ford 8340 (A53317)
