build your own multi machine (mill lathe),
/ build your own multi machine (mill lathe), #1
BHD
easten Colorado
JD 4020
/ build your own multi machine (mill lathe), #2
Did the builder mention what tolerances the machine will hold ? With good used machines going as cheap as they currently are, makes me wonder why anyone would want to build one. David from jax
/ build your own multi machine (mill lathe), #3
i think it's meant more as a tool for poor countries where even cheap used machine tools are unavailable and prohibitively expensive. i don't think it's real tight on tolerances, but it's probably more than good enough to help produce other pieces of equipment that provide what we consider to be basic necessities. i havent looked at it for more than a few seconds, but it sounds like it can be made from broken or non-functional items that are available most anywhere.
there were a number of Ideas that I thought had merit,
one the blocks are square, never really considered that before, I knew it but not considered it before,
another was the way the main spindle was constructed, and adjusted, could be used in other situations,
the idea of the over head arm,
and the idea of using the old block for the base, do to the weight and stability, of it, I could see it being used, for some other type of Ideas,
and for some I thought it could be the ticket for some one who is handy and minimal funds, ad to be able to get some type of machine for machining and metal working,
Or to make a specialty machine for some process,
just thought it was a cleaver idea and doable for many, with out any castings one would need to pour,
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
2016 Nissan NV2500 Cargo Van (A61573)
2016 Nissan NV2500...
karcher pressure washer (A61567)
karcher pressure...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
