Problem with Bushhog
/ Problem with Bushhog #1
indhrasena.reddy
Hi All, I recently purchased a 2007 3325 Mahindra.I can:t get the brushhog to go all the way to ground level.
The hydraulics travel up and down but stop about six inches from ground level.I used the hog late yesterday for about 10 minutes but when I went to lower the hog today it would not go all the way down.
/ Problem with Bushhog #2
Take the top link of the three point off and try to lower it with just your lower arms on the three point. If it goes to the ground the top link is binding against your lower lift arms. Some top link adjustment or maybe a different length top link should fix this.
/ Problem with Bushhog #3
My kioti has a couple different settings for lift arms,you can set them for lower or higher,than of course you can screw down or up on my right lift arm,check out this. Plus,you don't need a top link to brush hog[if its got a wheel on back end],I use a chain to let it float better.
/ Problem with Bushhog #4
I have a 4110 Tractor, i'm unable to engage PTO. The control switch is on manual and the PTO on/off switch lights up when I push it. The button and dash light comes On but does not engage. Can you please suggest me what should I do.
Thanks for your help!!!
Do you own two tractors or :confused2: :confused3:
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2014 TAKEUCHI TB228 EXCAVATOR (A65053)
2014 TAKEUCHI...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
