Unique ballast ideas
/ Unique ballast ideas #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
Based on some neat comments in other threads, I'm starting a "show us your unique ballast ideas" thread.
The first two shout-outs go to members Chelydra for a cool log idea and gwdixon for his drill bits!!!
Show us your accomplishments please :thumbsup:
/ Unique ballast ideas #2
I know someone is going to post that picture of an older man diving his tractor, left front wheel missing, with a heavyset eastern European woman (wife, I suppose) counterbalancing the tractor.
/ Unique ballast ideas #3
Hey, they can get that photo from several threads right on this site!:cool2:
/ Unique ballast ideas #5
I am honored to be included on jimmyj's list. My solution may be more sustainable, but the drill bits are classier. I need something like that on my car to hold back tailgaters - one look at those teeth, and they'll ride the brakes instead of the gas.
I actually looked around for something large, iron and free before shaping that stump. I'm thinking that a small engine block should be about right. Just run a threaded run through the crankshaft holes, and tighten down so it doesn't sway. Anyone here ever try that? Or maybe a stack of old truck clutch plates or brake discs.
-Chelydra
/ Unique ballast ideas #6
I thought of an old engine block (iron, not aluminum), too. I have a carryall box and find it easier to just load it up with some weight when I need a bit extra in the back (as opposed to hooking up the snowblower, for example). Still, it would be nice to have some weight that didn't stick out a lot in the back. Maybe a barrel full of concrete with 3PH bolts embedded in it?
BOB
/ Unique ballast ideas #7
Ok I'll post it, but no ridicule this time. The bulk of the counterwieght is a wide flange beam. It weighs around 500 lbs. It wasn't heavy enough so I annded the keg, which is filled with lead weights from car tires. That added another 300 to 400 lbs.
attachment.php
/ Unique ballast ideas #8
attachment.php
Are you sure it is only lead in that keg. :drink: :D:D
/ Unique ballast ideas #9
Wait...is that a hose I see running up to the drivers seat... :)
/ Unique ballast ideas #10
Don't have a picture, but I have a 5 gallon bucket filled with sand, hooks up a lot like the log does.
/ Unique ballast ideas #11
I used a cut down 55 gallon drum with a metal rod (for the 3 pt hitch) through it before filling with concrete.
Ken
MD, is that a culvert section with concrete in it? Looks really easy to take on and off. Great idea.
/ Unique ballast ideas #14
-Chelydra
Tail gater defense?
Here is an idea:
Airsoft M18A1 Claymore Mine
For ballast-- I just don't have anything as neat as yall...
J
/ Unique ballast ideas #15
Yes it's a piece of culvert filled with concrete and a 1" piece of shaft through it.
No top link required. By my calculations it weighs somewhere between 500 and 600 lbs.
M.D.
Found another spectacular ballast example. In an old post by DEON on his tractor. He called it "modern art".
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
