Gas grill opinions
/ Gas grill opinions #1
bdeboer
Central Ohio
Yanmar 2402D
I am looking for a new gas grill, and want something that will last. The cheaper ones seem to last 2-3 years before burner replacement. I also want something that doesn't have issue with hot spots etc.
There is a local Holland dealer, but I am not sure if I want to spend that much. They use a convection oven principle, how much longer do they take to cook?
I read an older thread where the Weber Genesis grills were well liked. How well do they hold up?
What about other brands like Jenn-Air?
Thanks,
I do have a Weber Kettle charcoal grill and like it for the indirect cooking. Just do not always want to wait on it for burgers etc.
/ Gas grill opinions #3
My experience is with several of the cheap ones and one Weber Genesis gas grill.
The cheap ones lasted about 2 years before they rusted out. My Weber is 10 years old and works fine. The Weber stays out in the weather (rain, snow, etc.) and has held up great.
Although my Weber is not broke, I am going to replace it soon -- I'm going to go with a permanent natural gas one. The new one will be a Weber.
Other than durability, the Weber has great burner control... something the cheaper ones really suck at.
/ Gas grill opinions #4
I have been researching drop in style gas grills for a outdoor kitchen I am in the process of building. The list of gas grill manufacturers is daunting to say the least.
I have read very good reviews of Weber grills. They say that they are the best in regards to even heating. The Genesis or the Summit are both supposed to be good grills. Unfortunately for me Weber does not make a drop in style grill. If they did it would be a no brainer.
I currently own a Char-Broil Commercial Series grill. Not the greatest for even heating, but has held up well for the last four years. Can't say that I'm disappointed in the least bit.
Mark
/ Gas grill opinions #5
The basic Holland grill is worth the price of admission - still grilling on one owned since 1992 and expect it to last at least another 10 years. As for cooking time on it - as an example, 4 - 1 1/4" rib-eyes cooked to medium (pink center) will take approx. 35-40 minutes (add 5-10 minutes in winter) after preheating grill 10 minutes. The meat, etc. will not have that charcoal-taste cooked on a Holland, but you won't have flare-ups or worry about burning anything. I've cooked everything from oysters to turkeys on it, and you don't have to stand over it and watch it. As Dave says, "If you're looking, you're not cooking".
P.S. I keep a cheap charcoal grill for when I want that open-fire flavor.
/ Gas grill opinions #6
If you find a good, long lasting gas grill be sure to let the group know. I've been looking for a new grill and have at least found that many seem to have standardized on the tubular stainless steel burners. I don't know how long those last, but they should at least be cheaper to replace. My four burner Brinkman used cast iron burners which decomposed in two years and are more expensive to replace than about 2/3 the original price of the unit. I knew when I got it that it was not a great grill, but it had a rotisserie and was stainless steel, relatively cheap and I figured it would last at least twice as long as it did. In fact, it is still working great....as a charcoal grill!
Chuck
/ Gas grill opinions #7
as one might think I think I know the answer to every subject:D I have to say that IMO the Charbroil Commercial series has been the best lasting Gas grill I've ever owned, its a 4 burner stainless steel, although no Fancy side pot/pan burner
which I never use anyway. I'd rather have the workspace to sit something down on, I purchased this grill 10 years ago and still expect 10 more years from it, I give just over 400 for it back in 2000, although they're costing much much more than that now, a cooking grill is one of them things you need to buy at end of season to get the best deals,:thumbsup:
/ Gas grill opinions #8
I've ben using my Weber Spirit 700 (forerunner to Genesis) since '98, and other than replacing the regulator and flavorizer bars it has out lived several of my friends grills. Replacement parts are easy to get if you need them.
The basic Holland grill is worth the price of admission - still grilling on one owned since 1992 and expect it to last at least another 10 years. As for cooking time on it - as an example, 4 - 1 1/4" rib-eyes cooked to medium (pink center) will take approx. 35-40 minutes (add 5-10 minutes in winter) after preheating grill 10 minutes. The meat, etc. will not have that charcoal-taste cooked on a Holland, but you won't have flare-ups or worry about burning anything. .
Thanks, for the detailed response.
/ Gas grill opinions #12
I have a char-broil, probably not a commercial series,
but it is mostly stainless, with the large cast iron
burners.
after 5 years of use, (year round) the burners were shot,
so i called them, and they provided me with burners, tents,
ignitors etc all under warranty. i was very impressed with that
service, and would consider them again for that reason.
this grill does have higher heat at the back 1/4 of the burner,
but i don't mind as I can move food around as needed.
I probably paid $350 for it 6 years ago or so.
/ Gas grill opinions #15
I saw some Webers at one of the local super markets. I think they were Genesis....around $400-500 on sale. I was surprised to see that the cooking grids were enamel coated stamped metal rather than solid bar-types. I plan to look at Webers at Lowes and/or Home Depot to see what they look like, since these may be some "special" discount versions.
One good thing about my old crappy grill was and still is the grids. They are heavy enamel coated cast iron (I think). Anyway, they certainly outlasted the burners and the poor quality sheet metal shields that were supposed to protect the burners from grease. I squeezed an old cookie sheet into the space where the burners had been and now I have a nice charcoal grill with heavy duty cooking grids. I bet I can still use the rotisserie over the charcoal fire, too. Maybe this should be in Bird's thread about our throw-away society!
Chuck
/ Gas grill opinions #16
I had a weber genesis for 12 years and it was/is still going strong when i gave it to my brother. The only reason I gave it up was my wife and I decided to go sailing for a coupe of years. During the time I owned it, I watched a good friend go through 4-5 hi dollar comercial / stainless grills. They either fell apart from poor craftsmanship or he had to keep replacing parts that would burn out or rust out. So now that we're back on land I purchased another weber. Went up one class and bought the Weber Summit last week. It was more expensive but I liked most of the features (some though are gimmicky) and from my past experience I'm expecting this one to be my last grill purchase. I'm not normally brand loyal but the ease of use and durability of the webers has me convinced I bought the right grill.
Good luck with your hunt.
/ Gas grill opinions #17
We bought a 'Charmglow' at HomeDepot a few years ago. Five burners with heavy cast grates. Has the stainless steel tube burners. Key problem we have had is there is a gap between the propane orifice on the burner controls and the burner tube. Somehow bugs get in there and clog the tubes. This results in poor flame on the burner and sometimes 'flashback' where the propane is going out the gap and not down the tube. Having a flame in this area heats up the SS panel behind the controls and melts the wire for the sparker. :mad:
I have one tube right now that is not working right so I have to take it apart again. Not a big job but messy. Originally all the tubes and spacers between the tubes were screwed down but apparently they didn't use SS screws as they have all rusted away. I don't really mind as that makes it easier to take apart and put back together.
This grill tends to be hotter towards the back than the front, which I like as some things cook faster than others. It has the ceramic burner for rotisserie on the back which is a really nice feature. Cooks a duck or chicken in 2 hours or so depending on size.
/ Gas grill opinions #18
I researched my grill purchase heavily about 3 years ago. I went with Weber Genesis and haven't regretted it for a moment.
/ Gas grill opinions #19
Close to 20 years (I think - a long time anyway) I purchased a Ducane grill that was supposed to last a life time. While it has (after various parts replacements) it doesn't cook as well as my Weber Silver Genesis. Long life is good, but if it doesn't cook well, it still isn't a lot of fun. The Weber, with three burners works great for indirect cooking and has enough heat to do great pizzas on the grill. So I would give it a high recommendation.
Having said that, I've become a convert to a Weber kettle with lump charcoal. You can have a screaming hot fire in about 20 minutes (the Ducane took about 15 minutes to preheat). Wonderful flavors and with the addition of a Smokenator 1000 you can do smoking and finish things off on your gas grill. Can't have too many grills :).
/ Gas grill opinions #20
I'm on my tenth year with a stainless steel Maker's Mark from Sam's Club...no complaints other than it is made in China.
UNUSED WOLVERINE TDB-11-72W-72" BUCKET (A64281)
UNUSED WOLVERINE...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
