Loader ML106 Loader question
/ ML106 Loader question #1
dtsdryseats
South Lyon Mi
Mahindra 2615
I have a 2006 2615 gear with a ML106 loader. I am reading that it has a "float" otion, but I have never been able to make it work. Can anyone help me out on IF I actually have the option and if so, how do I operate it?
Thanks, Dave
/ ML106 Loader question #2
Howdy Dave, I own a Mahindra 4025 with the float function. The way that it works on mine is to lower the boom to the lowest setting, then push the joy stick a little harder and it will snap into the float position and thats all there is to it.
Good luck.
/ ML106 Loader question #3
I have an 04 of the same model but with HST. Loader is the same. You already know if your pull back the joystick the loader goes up, pushing forward of course it goes down. Try this, raise the loader then when you push forward it feels like you hit a stop. Push harder and the stick will go further and stay there allowing the loader to float down.
/ ML106 Loader question #4
I have an 04 of the same model but with HST. You already know if your pull back the joystick the loader goes up, pushing forward of course it goes down. Try this, raise the loader then when you push forward it feels like you hit a stop. Push harder and the stick will go further and stay there allowing the loader to float down.
Works the same way on an 06 gear. At least it does on mine.
That's how I understood it to work. I had tried this before with no success. I will have to try again......is there a chance that I do not have this option or that it isn't working for some reason? I bought the tractor new and I have never known it to work or if I even have it. I will give it another shot today and get back with you. Thanks for the responses. Sure would be a handy option to have at times!
/ ML106 Loader question #7
You certainly have the option. You won't find a loader by any company without it. There is the possibility that it is not functioning correctly. You may want the dealer to check it out.
/ ML106 Loader question #8
Dave, I recently bought a 2007, 2015 with an ML-104 loader and it wouldn't go into float either. I am guessing that the ML-106 loader uses the same hydraulic valve made by prince hydraulic's and the detent assembly is corroded and stuck. I did a search here for float, or loader float or something and found that this is fairly common with this valve. The problem is that moisture gets in the detent assembly and things get rusty. Mahindra does not sell parts to repair this , my local dealer checked for me. They want to sell you the whole valve for more than $400. It can be repaired, I repaired mine myself. The detent assembly is located on the bottom of the valve inside an aluminum cap held on with two socket head capscrew's. The parts inside are a spring, tapered plunger, and two ball bearing's, these fit in a sleeve with a groove in the bottom. The rust causes the ball bearing's to dig into and wear grooves in the tapered plunger and the ball bearing's will no longer snap into the groove in the bottom of the sleeve. Your's may not be this bad and may only need cleaning, greasing and new ball bearing's that you can get from true value hardware like I did. Mine was worse than this and I "TIG" welded the grooves in the tapered plunger and re-fit it by hand with a file and fine sandpaper ( my metal lathe is apart at the moment). I finished it off by polishing it on a felt wheel with polishing compound in a dremel tool. Now it work's like a charm. The ball bearing's I bought are 1/4" in diameter and were chrome plated, maybe stainless would be better but I could'nt find any. You should also have a fast dump position if you move your loader joystick to the right until it snaps over, although it is not a maintained detent and you need to hold it there, if it's like mine. You can also remove the ball bearings and it will work but you will need to hold it in float. Or maybe you can swap plungers and bearing's with the fast dump position, the part's are the same except for the sleeve at the bottom so don't swap that. Check it out and let us know what you find, I'm betting this is the problem. Good luck, Ken .
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
Caterpillar C Series Backhoe Service and Parts Manuals (A63117)
Caterpillar C...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2006 Volvo VNM T/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM T/A...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
