Concrete Question
/ Concrete Question #1
luscsmith
I am having a concrete drive poured and would like to know if I can substitute rebar and/or wire with thicker higher psi concrete with fiber.
Thanks, Scott
/ Concrete Question #2
Thanks, Scott
Don,t know where you live but will tell you here in N.MN. the fiber mesh doesn,t hold up as well as the wire mesh.And I was told by the cement guy,s that sun light isn,t good for the fiber.I,v had both poured and will stick with wire or rebar.Dave
/ Concrete Question #4
Scott, supposedly rebar or wire are placed in tension areas of the concrete pour as cement is considered to have zero strength in tension.:)
On your question I'm so many years out of date I'll not hazard a guess.:eek:
/ Concrete Question #5
Thanks, Scott
Scott,
I talked to a friend of mine that does concrete work for a living. His reply was that the fibre works fairly well inside of building but does not last as well when exposed to the elements.
I have not seen them but he said there is a company or companies that are experimenting with plastic or fibre rebar. The reason being it would be imune to raod salt and in theory would last longer.
For today I would use rebar and or heavy mesh wire with good concrete mix. aound here the difference in price from 5 bag to 6 bag mix is $6 / yard.
Roy
/ Concrete Question #6
Utilizing a higher strength concrete will improve the compressive strength of the concrete but will not appreciably change the tensile strength. A 2*0=0 sort of thing. The steel reinforcing takes the tension up in the concrete to prevent differintial settling and to deal with some internal stesses. I tried fiber instead of rebar for a sidewalk one time and it improved the strenght of the concrete but did not prevent the individual sections from settling at different rates causing the edge of one section to be slightly higher than the edge of the adjoining section. To sum up I would recommend utilizing the rebar/welded wire.
/ Concrete Question #7
Unless the steel is pre-stressed (Pulled and held in tension while the cement hardens), the only thing the steel does is keep the broken concrete sections reasonably together. I've used the higher strength cement mixes without steel at the same thickness and been surprized at how crack free its been. But, these were small sections which replaced old broken ones, and the setlement of the underlayment probably had a lot to do with it, too.
/ Concrete Question #8
Ummmm.....No.
If that was the case parking ramps would fall down under their own weight.
/ Concrete Question
I am planning to pour 5" of 4,000 psi, will that be good for a drive?
Scott
/ Concrete Question #10
Scott
That is what I used on my driveway last fall. 14' wide, wire mesh and used 2 rows of rebar near the outside edges. 14' is probably wider than needed but nice for larger trailers.
/ Concrete Question
Should I drop the fiber and spend the money for extra cement?
Scott
/ Concrete Question #13
If I was pouring a drive for you I would pour 5" of C4 (~4500psi.) with #3 rerod 2' o.c. both directions place on 1.5" plastic chairs. I would place a second mat of bar in the corners setting on 3.5" chairs.
Fiber is a waste of money and looks like crap IMO.
/ Concrete Question #14
What pre-stressing does is place the concrete in compression so that when it is loaded none of it goes into tension and fails. Concrete is great in compression, but will fail under tension.
/ Concrete Question
Thank youal very much. I just returned rom the hardware store with my wire meh and rebar, hope they start monday.
Scott
/ Concrete Question #16
Many years ago my steel supplier showed me a diagram in one of his engineering and steel sizing books.
It showed that if you poured a 8" x 8" x 8' column of concrete and laid it on its side supported only at its ends it would fail under its own weight.
Now that same column with 2 properly placed #4 (1/2") rerods laid on its side and supported at the ends would hold up (this is the part I don't remember, too many years ago) alot of weight point loaded at the center of the span.
So steel in concrete is everything.
/ Concrete Question #17
But ... Would that 8 x 8 x 8 column survive if fiber was use in the concrete?
I doubt it, just asking. I agree with those that say use steel. I don't trust little fibers in concrete.
/ Concrete Question #18
I doubt it too.
/ Concrete Question #19
You are absolutely correct. We build concrete arches (up to 84' spans), bridges up to 55' span, concrete pipe up to 12' diameter and steel is everything, no steel and most of it would probably collapse from it's own weight. Fiber adds strentgth but not as much as steel but you'll be hard pressed to get any kind of finish to it as the fibers tend to stick out of the concrete like loose threads.
Home : Shaw Pipe
Steve
P.S. Image #12 on the photo gallery of the arches shows a partially finished steel grid in one of the arches.
/ Concrete Question #20
Thanks, Scott
Not with any successful expectations. Fiber is for prevention of reduction of surface shrinkage cracking. It will not substitute for much of anything in the manner of primary reinforcement. As a Civil Engineer, I have worked in concrete many years with research on this issue. Take it or leave it. Your concrete will be the proof in the pudding.
Steel in concrete is indeed the essential reinforcement. Wire mesh is a waste of money.
(3) HOLE STAINLESS STEEL SINK W/ SIDE TABLE (A65054)
(3) HOLE STAINLESS...
IRON RHINO IR1000 Mini Skid Steer (A68134)
IRON RHINO IR1000...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
KOMATSU WA-250 GP Bucket (A68134)
KOMATSU WA-250 GP...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
