Gravely Promaster 60
/ Gravely Promaster 60 #1
gameboy68
I purchased this zero turn lawnmower about 2 months ago, since then we have had a couple problems. My main concern right now is that the lawnmower does not shift gears like it should. I do not really understand how it works but it has 4 gears to shift into. You shift it by moving a lever either left, then up or down which would shift it into either 1st or 3rd gear, and then shifting right, then up or down goes from 2nd gear or 4th gear. The problem is that the lawnmower is being unresponsive to any gear i put it into and i dont know why. The only thing i can do to get it to move is to shift it into 1st gear after waiting a couple minutes and it will have a little bit of power. The gears sometimes do work but it is only when it wants to and can never say how long they work for, before they just give out and have no push. Yes i do move my forward and reverse lever and make sure i am going forward, and the brake is not on while i try to move either. If anybody has any ideas of what is wrong i would greatly appreciate some insight to this.
/ Gravely Promaster 60 #2
Most of them have an 8 speed transmission. There is a lever to go from Hi to Lo range. If the lever is inbetween both, then all you'll get is reverse gears and maybe some movement out of 1st gear forward.
/ Gravely Promaster 60 #3
I have a ProMaster 60 with a 20 hp. twin cyl. kohler . I am looking for a service manuel or wiring diagram for it . Any suggestions?
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
1143 (A63745)
1143 (A63745)
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
