Engine Manufacturer?
/ Engine Manufacturer? #1
robertwhite
So I am seriously thinking about buying a CT335 and I realize that I don't know who makes the engine in a Bobcat/Kioti.
Little help?
/ Engine Manufacturer? #2
Little help?
Daedong in South Korea builds the engine and tractor. I get confused sometimes as to who owns who, but I think Doosan owns both Bobcat and Daedong, but Daedong sells the Kioti line while Doosan has started importing these as Bobcats. I may have that order wrong though.
I rebuilt the engine on my 95 model LK3054 and I can say they are well built, simple and rugged.
/ Engine Manufacturer? #3
Daedong is a separate entity. Doosan bought Bobcat a few years ago from Ingersoll-Rand (they may have bought IR, too, I don't remember).
/ Engine Manufacturer? #4
6-16-13, well done! Did you need any special tools?, what parts did you replace...? Tell us more...
/ Engine Manufacturer? #5
IR sold off Bobcat around the crash. They are also Eaton, Cuttler-Hammer and Thermo_King too. Supposedly Kubota will no longer supply engines for the Bobcat skid steer and those motors will be replaced with one's manufactured by Doosan (not Daedong).
/ Engine Manufacturer? #6
I have had a 335 for almost a year now, having put over 100hrs, (400+ total) I can say that the ct335 is an excellent tractor in all areas. I have the shuttle model and planed on keeping it for a couple years and flipping it however the more I run it the more I plan on keeping it.
/ Engine Manufacturer? #7
Yes, I've had my CT235 for a few years and 160 hours and I'm very happy with it.
/ Engine Manufacturer? #8
When did Bobcat stop making tractors? My local Kubota/Doosan/Bobcat dealer has dozens of Bobcat tractors(which for some reason they don't seem too concerned about selling).I was told they are no longer made.
/ Engine Manufacturer? #9
I believe there were some 2013 models but I don't think very many. I'm not exactly sure the date they decided to pull the plug. Too bad seemed like a good fit I know I love mine. Where is it that your local dealer is located?
/ Engine Manufacturer? #10
Stockton Mexifornia.
/ Engine Manufacturer? #13
Since my last post I have racked up another 50+ hours, mostly pulling saw logs for my bandsaw mill. The Bobcat tractors are very well made, comparatively to Kubota I really appreciate the extra weight, in some application (bush hogging) which I don't do I think the extra weight might be a hinderance. The ct335 can easily pull 2 17' long 20" pine logs over some pretty uneven ground, after breaking my winch cable several times I have decided that 1 log going slightly faster (mid range 2-3-4 gear) results in just as much wood by the end of the day.
As of right now I have around 4000bf of pine pulled out in just a little over 2 days, plus some firewood. As of late the 4+ feet of snow has made going pretty slow. Even with the R4 tires and good chains I was able to keep my twitch trail open with 30" of fresh powder.
The changes I would like would be slightly larger front tires, rear wheel weights (I don't need more weight with the backhoe but could use the extra weight pushing snow in the winter) & a hydro shuttle shift.
I originally had planned on using the tractor for a year or sell and upgrading however the more I use it the more I like it. If a clean ct450 came for sale locally I would'nt hesitate to move up. The backhoe is small but very useful.
/ Engine Manufacturer? #14
/ Engine Manufacturer? #15
I love it. It's the nicest tractor I have ever owned. Such an ease to operate. It is my first Hydro static tractor and I can't believe how easy it is to operate. This is quite a strong little tractor I have found that it is the perfect size for my uses.
/ Engine Manufacturer? #16
I would like to try a hydro tractor, its seems for loader work and close quarter stuff the hydro is far superior, however it seems with a gear shift one can run the engine at much lower RPMS. What rpm do you operate at with your hydro tman?
/ Engine Manufacturer? #17
Yes that is a nice thing about gear drive. It's worth the trade off for me It just depends on what I'm doing. For most stuff no less than 1800 rpm. But I normally hover around 2000 rpm unless I need max power or if I'm running pto implements. 540 pto rpm is some where around24-2500 rpm if I remember correctly.
/ Engine Manufacturer? #18
I have only run one larger hydro, it was a kubota around 50hp, nice smooth tractor with the ability to move forward and back with great control. The one thing I did not care for was the RPM's, dragging wood I am glad I have a SST, while loading the sawmill I wish I had a HST.
/ Engine Manufacturer? #19
The newer Daedong hydrostats, the manufacture of both the Kioti and its white brother the Bobcat have a "linked" pedal" arrangement so that you can run the throttle at a low level and when you step on the hydro pedal it will rev up the engine. The Grand L Kubota's and some JD's have had this for some time. and the new NX series Kioti's have this now. My Kioti DK35se , the orange brother to the Bobcat CT335 does not have this, so I often change the throttle setting according to the power needed.
/ Engine Manufacturer? #20
IF you are talking about Bobcat "compacts"? Bobcat never did make them, They bought them already painted in Bobcat colors...
SR
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
New/Unused Wolverine Quick Attach Ripper (A61166)
New/Unused...
Holland Tandem Axle Rear Truck Frame (A61568)
Holland Tandem...
2018 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 FREIGHTLINER...
