Pat's Easy Change MX5000 slide-out 3pt ends
/ MX5000 slide-out 3pt ends #1
tmxj
I'd like to order a pair for my 2006 Kubota MX 5000, but I am a long way from the tractor for several months. Impossible for me to measure the slide-out dimensions. Does anybody have the dimensions? It's simple to pull out and to reassemble, pull the retaining pin, then pull the large pin. I had it apart last time I was home, but I did not know these were available, so I didn't measure it.
New Slide In Models
MX5000 vs MX5100 3 pt lower link slide-in ends, are there any differences? Are the part numbers the same?
/ MX5000 slide-out 3pt ends #3
i have a mx5000 with the telescopeing hitch. is that what you or talking about? joe:thumbsup::thumbsup:
/ MX5000 slide-out 3pt ends #4
Since you're away from your tractor, why not call your dealer? He can give you a definitive answer.
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
