3 point linkage for moldboard plow
/ 3 point linkage for moldboard plow #1
downslope
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I notice on some tractors the 3-point lower lift arms can be connected to arms that go up to rockshaft either thru a slotted hole or a fixed round hole by relocating the pins. I guess the slotted connection is supposed to float somehow. How should it be set up for using a 3-pt moldboard plow?
My guess is that since the infurrow side has to be set shorter it would be better to use the fixed attachment points, but I'm not sure.
/ 3 point linkage for moldboard plow #3
I wouldn't use the slot, I always use the fixed hole. Seems like you would have poor depth control on a 3 - point attachment.
Our tractor has the slot, but never seen an attachment that calls for it.
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
iDrive TDS-2010H...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
