Ford 1700 Unknown knob
/ Ford 1700 Unknown knob #1
kinglouie63
On my 1700 if you were sitting on the operators seat and look between your legs (insert comment here). There is a adjusting knob. It is mounted on the vertical and the top of it faces forward. it looks a little like a relief valve adj, in that it is twisted and turns a threaded rod about 3/8" or so. Any ideas what it does? Mine is set up and if I don't need it I'll leave it alone for a while.
Thanks Louie
/ Ford 1700 Unknown knob #2
It may be the same thing on my Kubota that controls the speed of the 3 point hitch lowering rate.
/ Ford 1700 Unknown knob #3
This knob controls the speed the TPH lowers. If you want it to lower slower tighten the knob.
Bill
/ Ford 1700 Unknown knob #4
I agree with the others.
If everything is working to your satisfaction, I'd suggest you not fiddle with your knob.
BOB
/ Ford 1700 Unknown knob #6
BOB
"Not gonna do it, wouldn't be prudent..."
/ Ford 1700 Unknown knob #7
You might go blind too.:laughing:
The only time I slow my 3 pt down is with something borderline too heavy for the tractor. This keeps it from slamming down too hard.
/ Ford 1700 Unknown knob #8
With some difficulty, I managed to resist adding comment on another thread that recommended "always check your nuts". I just prefer to focus on the job at hand and not be distracted while operating the tractor.
BOB
Thanks all, I gather it's a meter out flow controll. I'll not play with any knobs..... thats rhe Mrs. end of things
/ Ford 1700 Unknown knob #10
Technically, it sounds like it's probably the rockshaft control valve? I adjust mine as needed, depending on the weight of the implement or which one I'm using. For a bushhog, you want it to drop fairly slow so you don't break the tailwheel yoke. For a BB, you want to drop faster since it can take the abuse of hitting the ground fairly hard. Other implements are probably somewhere in between.
/ Ford 1700 Unknown knob #11
the knob is rate of drop adjustment and has absolutely nothing to do with rock shaft. It is a manual needle valve that regulate how fat oil can be dumped off from the lift cylinder back in to rear diffy. Clockwise and implement drops slowly, counter clockwise and it drops fast.
JC,
2022 EZ-GO ELITE...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
35in AIM Tooth Excavator Bucket (A64194)
35in AIM Tooth...
