Need help deciding what to buy...don't know much.
/ Need help deciding what to buy...don't know much. #1
Bunnyblaster
Member
Southern IL
JD 3720
Like everyone else in the world, my wife and I are looking at CUTs. We currently have a Long 445 we've been using for mowing, but its time we get something with a loader. I don't really think we need the 43 hp the Long has, and I'd like something that sits a little smaller. We've got 60 acres in southern IL, and its not really flat. Theres an area of CRP that I want to convert to food plots, so I need something that will pull a small disc ok. Other than that I'll use it for mowing and loader work. We've got lots of stuff to clean up on the property.
I've got price quotes on three machines with loaders so far
Kubota L3400 - $18,250
John Deere 3038E - $17,750
John Deere 3032E - $16,750
I need to take a close look at each of them. The way I understand it, the E series Deere 305 loader will not quick detach from the tractor, while the L3400 will. Trying to decide if this is a must.
Any thoughts? Any other machines I should look at? Can I get the prices down any, or is this about as low as they go?
thanks
Aaron
/ Need help deciding what to buy...don't know much. #2
I think it would be a must to remove the loader. When you are doing some tasks with the tractor on hills, the front loader takes away traction on the rear and can become very dangerous. Also, leaving the loader on all the time wears out your tractor front end a lot sooner. Prices seem fairly inline. If you hit them with a trade in of the Long, the prices will be elevated until they find out for sure your intentions of buying outright or trading in? Suggest buy new tractor outright and sell the Long privately. Ken Sweet
We've got the Long for sale. Just put it up on Craigslist and a local Trader paper yesterday. I'd like to sell it outright. Figure I'll give it a few weeks and see what bites.
I do think I'd prefer to take the loader off from time to time.
Also got a quote on a JD 3320 - $23,000. I've seen new ones on tractorhouse for $21k or so. Thats a little more than I want to do though. Any other options I'm overlooking?
/ Need help deciding what to buy...don't know much. #4
If you have quotes from dealers in your area, That is about all you can do, unless you want to drive some miles and buy cheaper and bring the tractor back to local dealers for service and warranty work. Pay close attention to how a dealer treats you and his reputation for follow up after the sale. Ken Sweet
/ Need help deciding what to buy...don't know much. #5
John Deere has parking stands available for 3032e/3038e tractors with 305 loader list price $325
/ Need help deciding what to buy...don't know much. #6
thanks
Aaron
If JD and Kubota are the only local dealers (say within 75 miles), then I'd select a tractor from one of those guys. Folks generally don't want to be too far away from their dealer when service is required (hauling charges can be high).
If you have other dealers nearby, then look at their offerings.
I've owned a Kubota (2005 B7510 HST with the LA302 FEL, 21 hp engine, 17 hp pto, 4WD) and now have a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, gear tranny). Both are good machines. My guess is that Mahindra will price out lower than JD or Kubota for comparable tractors with the same features.
/ Need help deciding what to buy...don't know much. #7
The Loader can be a pain when mowing. Otherwise there is probably no need to remove it.:D
/ Need help deciding what to buy...don't know much. #8
I don't know anything about these model John Deeres, but John Deere makes very good tractors. To me, on this size tractor an easily removable loader would be a must have. Generally Kubota loaders are very easy to remove/install.
/ Need help deciding what to buy...don't know much. #9
You might ask about the B3300SU package, 33hp with 25PTO hp. with a quick detach loader. It does not come with a mid pto but maybe you don't need that. It should fall in the same price range of the Deere 3032E or slightly lower.
Curt
Thanks for the help. I've got 2 Kubota dealers within 30 min or so, and probably 3 or 4 JD's in the same distance.
Also looking hard at used machines. Found a good deal on a L3400DT, but didn't know if I would get along ok with it being geared. My current old tractor is geared, but I was originally wanting HST. The same dealer has a L3240HST for a couple grand more with the same hours. Both have FEL. The L3240HST has a Box Blade, and the L3400 has a box, and mower.
Is the Hydro L3240 worth a couple grand more?
/ Need help deciding what to buy...don't know much. #11
It would be to me and the Grand L Series has other features not found on the other models such as tilt steering.
/ Need help deciding what to buy...don't know much. #12
Before you get to far into the buying if you were using a 43 hp tractor for mowing what size mower do you have. The rule of thumb is 5 PTO hp per foot of mower. I wouldn't undersize the tractor too much for 60 acres if you mow much of it.
Another worthy option on the loader is the quick attach bucket systems. Be able to hook up a set of forks is great for many things around the farm.
MarkV
/ Need help deciding what to buy...don't know much. #13
So it looks like Kubota and JD are in the running.
HST tractors are handy for back and forth work with the FEL or mowing in tight or irregular spots.
I plow my 6-acre hayfield with an old 7-ft Towner offset disc with that Mahindra 5525 I mentioned previously.
It's a heavy disc--probably 800 lb-- and I add about 500 lb of extra weight with those concrete-filled buckets strapped to the disc to get the disc to bite better and use a tire drag to help break up the clods. I tow it at 5-6 mph in 4L gear. You need high ground speed to get discs to work properly.
So the tractor hp you need will depend a lot on the soil condition in your food plot areas. My soil is pretty gravely and hard, not like typical Midwest soil so I have to make several passes over my hayfield at different angles to get the plowing done right. If your soil is softer, your disc probably with bite deeper and you won't have to make as many passes as I do. But, remember, the deeper the disc bites, the more tractor hp you need to pull it. I'd check with nearby neighbors to find out what tractor hp and what type and size discs they use and recommend.
/ Need help deciding what to buy...don't know much. #14
Bunnyblaster,
I would consider moving up in size, look into a 50 to 60 hp tractor. While it may seem higher in cost, it is cheaper than trading up in a year or so. I would think at a minimum you need to be able to handle 6' implements. A 60 hp tractor will work with 6' thru 8' implements quite well.
/ Need help deciding what to buy...don't know much. #15
Sorry for interrupting this great conversation but my "Fur Buddies" really really like your user name:laughing::laughing:
Yeah, my pups love it too. They actually caught a rabbit earlier this year...on Easter Sunday no less. Bunnies don't stand much of a chance when being chased by two german shepherds with high prey drives.
Back to the tractor stuff. I spent Saturday looking at dealers in the area. And after sitting on the machines, I like the 3320 more and more....even if it is higher than I wanted to do. I also liked the L3240 model Kubota. So, now its down to these two really. I liked the JD pedal configuration better, but what about loader options? Doesn't the Kubota pretty much come standard with the skid steer type quick attach? The JD 300cx has it as an option, but I haven't priced how much extra that is.
The big reason I don't want to go with much bigger of a tractor is that much of this work is going to be done in the woods. I think a bigger machine won't get through our property as well. I won't be mowing much, and I'll buy 5 ft mower when I get the new machine. The other one is being sold with the Long 445.
The Kubota dealer I would probably go with is 30 min away, but the JD dealer is just up the road about 10 miles. hmmmmm.....
/ Need help deciding what to buy...don't know much. #17
I don't think you will regret buying either, my preference is for the Kubota, but that is just a personal thing and could not come up with any compelling reasons to pick one over the other. Good luck
/ Need help deciding what to buy...don't know much. #18
Don't know if skid steer FEL QA is a standard Kubota feature, but I have it on my Mahindra 5525 and highly recommend it.
Also, get double or triple remote hydraulic attachments on your new tractor. It's easier (and likely cheaper) to get these when you buy the tractor than retrofitting them afterwards. Here's a photo of the triples on my 5525
I also recommend a metal safety shield to protect yourself when you're using your bush hog rotary mower. Here's mine-- a piece of expanded metal screen from Home Depot (or a local weld shop) attached to the ROPS with hose clamps (don't drill into or weld to the ROPS).
/ Need help deciding what to buy...don't know much. #19
[/QUOTE]
[/QUOTE]
I took a pretty good lick in my back while operating a rotary cutter about 10 years ago. I went to the house to have my wife see what the damage was and she found buried in my back a piece of fence wire about 3/4 inch long. She just pulled it out and no long term harm came of the incident, however, I went straight to my shop and cut a piece of plywood to go behind my tractor seat. That metal screen or something similar would be a must for my cutting, if you don't have a cab. Ken Sweet
That metal screen is a great idea. I will definitely put one of those up. A buddy works at a welding shop/manufacturing facility. I'm sure he can hook me up.
Thanks for all the info. Looks like its down to the best deal I can find. I'd like to find a used one, but it seems they're few and far between...and not much off the cost of a new one.
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A59228)
2014 Jacobsen AR3...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
