JD 5400 "Whirrs" when in reverse...
/ JD 5400 "Whirrs" when in reverse... #1
drzg2000
Hi,
I recently bought a 1995 JD 5400 with manual transmission. It works fine... but when I reverse the transmission "Whirrs".. Is this normal? It's pretty noticeable, just wondering if this is a symptom of anything wrong.
Thanks!
Martin
/ JD 5400 "Whirrs" when in reverse... #2
I'm going to suggest that sound is whine rather then a "whrrrr". If I'm correct, there's probably no problem. My 790 used to whine in reverse (but I cannot recall if my old 670 did, even though it was quite similar to the 790).
Gears do that. Backlash (a measurement to ensure proper mesh of the gears) is checked in the primary driven direction. If the backlash is off (even if in allowable specs), those gears may be noisy (the "whine").
Older pickups and other trucks (up to the 1970's, Id guess) with manual transmissions used to be quite noisy in this regard.
However, I'm guessing that's what you hear...without hearing it myself, I can't say for sure. I suggest you ask the person you bought it from, or a local Deere dealer.
Absolutely right; now that you mention it. It's more of a whine.
It sounds like some manual cars do in reverse; but much louder which is where my worry was coming from.
Thanks for your help!
/ JD 5400 "Whirrs" when in reverse... #4
Remember, no sound absorbing material (carpets, etc.) on a tractor. It's going to be noisier. Also, low noise in automotive tranny and differential gears is one of the design criteria. I doubt too many tractor manufacturer require it...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
LOT LOCATIONS (A59914)
