Loader B3030
   / B3030 #1
tthopskin@yahoo.ca
Gold Member
madoc ont 30 t years
and i just got a 580 c case backhoe real good shape got another kubota 2100 .. 2 - 684 IH 2 -8 N Ford had B275 IH MF # 50 work bull MF 35 all redone 65 mf 1750 kabota
Kubota B3030 lost down pressure changed filters worked after then stopped :confused2: any one know of any thing fuse or valve shut ??????:mad::confused::confused::confused:
   / B3030 #2
My tractor (B7800) does that if I bump the 3ph control lever and it stays in the up position. That pretty much does the same thing. Loose down pressure and another function that I can't remember now. I know that the B3030 has a different 3ph setup, but I though I mention it.
   / B3030 #3
Check the hose connections on the FEL. If one is not fully seated that could be the problem. The B3030 has 3PTH position control. Lever position will not affect the FEL.
   / B3030 #4
I have had this happen and after re-seating all the connections, it worked fine.
   / B3030 #5
Ditto. Same thing happened to me with my B3030. Sure was confusing at first, though....
   / B3030 #6
Keep an eye on the hoses that go from the loader valve to the solid alum lines. The elbow on the piston can sometimes catch the package of hoses and pull them down. Mine just ripped one of the lines after 15 hrs of use (brand new tractor blowing lines). Dealer is looking at it now replacing the 4 lines and trying to route them away from the piston elbow.
   / B3030
:thumbsup:first thing checked
   / B3030
thanks for the advice ...still no down presser when I find the problem I will let you know I checked the quick couplers first-- all good ??? i will find it---- thanks again :confused:
   / B3030
can you beleve the dealer came pulled the cylinders apart and then took them in my mind nothing wrong with them have too wait and see the story that comes out of this one :mad:
   / B3030
the problem was the release valve :thumbsup:
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52128)
John Deere 5090E...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
Payment Instructions (A47384)
Payment...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
