JD 346 Baler
/ JD 346 Baler #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am looking at a JD 346 baler
Any comments one way or another on this model?
D.
/ JD 346 Baler #2
My wifes uncle had one. Just a beast, take hay as fast as you could feed it. His had a kicker and realy could fill a wagon fast.
/ JD 346 Baler
/ JD 346 Baler #4
OK I won the auction:
john deere 346 square hay baler - eBay (item 150443595220 end time May-20-10 20:35:19 PDT)
I wont be able to go get it until after Memorial Day weekend. My JD dealer has a very good tech for square balers. I am thinking of just dropping it off there and having him go thru it and give me a report.
D.
Congrats on your new baler. Looks real nice. Price is in line with what others have paid on eBay for similar balers in good condition like yours (I keep track of the eBay auctions for haying equipment so I have some idea of ballpark prices people are paying for this type of gear).
Also nice that it's located in TX so you don't have to journey too far to pick it up. I was fortunate in finding an MF124 baler two years ago that was only about 35 miles from my place. Towed it home via the back roads with the F150.
/ JD 346 Baler
One of the tires has no tread. We are going to trailer it home.
D.
/ JD 346 Baler
Good to know i didn't get hosed on it. I hope it is in good shape. The guy has been baling with it. We will see how it looks in person and what my JD tech says.
I am wondering if it will run the new style twine. The poly twine. All the horse people around here love that stuff. My hay is finally horse quality. I want to get a horse quality price for it. :)
/ JD 346 Baler #7
Just noticed this thread... (I'm a little slow on the uptake sometimes!) :D Baler looks to be fairly straight - no major bruises evident in the pics!
Old farmer in SD tells me that when you see a small square baler using sisal twine that the knotters are likely getting worn, billhook, etc. and can't use the poly. Slips the knots too easily and won't tie consistently. Not sure myself...
'Course there are folk's that won't use the poly cause it doesn't "degrade" as it's not a natural, organic product... So, they won't buy poly tied bales.
I'll be waitin' to see your report and pictures from your square bale operation.
Best of luck.
AKfish
/ JD 346 Baler #8
Old farmer in SD tells me that when you see a small square baler using sisal twine that the knotters are likely getting worn, billhook, etc. and can't use the poly. Slips the knots too easily and won't tie consistently. Not sure myself... AKfish
I used sisal in my old IH-37 and I still use it in my new JD. I hate the plastic stuff. You drop some sisal on the ground, it just stays there and rots. The plastic will manage to find a piece of rotating equipment and tangle itself in it.
/ JD 346 Baler #9
Back around 1980 I had one of these balers. It was a mixed bag at best.
It was new, well, tech used as it had a couple tons of hay through it. Here is the issues I had with it:
* Instruction manual was incorrect for timing the needles. Time the needles to the manual and you would be breaking them quickly. I went through a number of needles until I had a JD mech tell me the manual was wrong.
* Broke a knoter frame for no apparent reason. Replacement was a generic replacement. Came with instruction on what had to be modified depending upon which model baler it was going on.
* Had to replace the crank big-end bearing a couple times every season. It just wasn't up to the task when running heavy loads through the machine. Always carried a spare with me as you never knew when a bearing was going to go. This bearing came with a custom ID and not available anywhere other than a JD dealership. I came up with a workaround and bought bearing from a bearing supplier and paid something like a third of what the JD dealership was charging.
* Early models came with the tongue jack that was a real widow maker. Could have done some real damage when the handle came flying off and missed my head by a couple inches.
If one is prepared for some of it's short comings, the baler could push a lot of hay through it.
/ JD 346 Baler
Thanks for the info. I"ll have to make a note of that.
I may have a chance to get a 346 parts baler. Not sure I need a couple one laying around. If I get it, I may part it out.
Which bearing is that? I don't know what you are talking about, but if I need some spare parts I want to have them on hand.
Mine has a jack back on the case.
I dropped it off at the JD dealership. It will be interesting to see what all they find. First off he said one knotter looked good, the other one needed to be timed.
Said the plunger bearings are shot.
No clutch plates in the clutch.
Grade 8 bolt in the shear pin
They are going to get me an estimate early this week. I hope it is not too painful.
D.
/ JD 346 Baler
Here are some pics.
D.
/ JD 346 Baler
The pick up has all kinds of twine wrapped up in it.
The gauge wheel is there but had been patched.
The paint job is ugly. I don't think anybody would try to steal it. I kinda wish it has original paint. :)
D.
/ JD 346 Baler #13
D.
Sorry about your troubles. But that's about par for the course with these old balers. The two friction plates in the slip clutch on my MF124 baler were completely worn away. Found replacements (low bidder at $30 each) from an MF dealer in Maine. So far I haven't had to do anything to the plunger except check the timing.
/ JD 346 Baler #14
Yep... I've had to cut that plastic stuff off of cows and horses hooves. Pretty nasty situation if you don't catch it right away.
Takes weeks of spraying that purple antibiotic spray on the ankle to get it all healed up again.
AKfish
/ JD 346 Baler #15
D.
I bought $450 of spare part "consumables" at the local JD dealer for the 336 near my Dad before I headed back north. Set of needles. Box of pickup teeth. Couple dozen shear bolts. New teflon bushings for the feeder arm, etc.
A new tire, too.
As flusher noted - gotta expect it with those old ones...
Waitin' to hear how everything goes with the "Kachung, click and clank" as it trips and drops the bale!
AKfish
/ JD 346 Baler
Heck i knew it would not be perfect. I paid $2700 for it and I figure if I have to drop $1000 - $1500 into it to get it right that is probably a deal considering new balers are $20K.
They will have a quote for me early this week.
D.
/ JD 346 Baler
AKfish
What kind of twine should I be using?
I know nothing about square baling.
D.
/ JD 346 Baler
D.
A new tire, too.
AKfish
Are the needles the whole piece? Or are the ends replaceable?
Do you have a pickup guide wheel? I figure that should save the pick up teeth.
Couple dozen shear bolts? Really? How often to they break? Maybe that is why there is a grade 8 bolt on mine...
Teflon busings where?
Man - sounds like I need an ammo box full of parts.
D.
/ JD 346 Baler #19
I brought 8-two roll bundles of twine back with me, too. A couple of those bundles are sisal. Might try both if one is more of a problem; but the baler has plastic in it right now.
The needles are single piece and bolt up to the baler (needle frame) with a couple of bolts.
Yup, the 336 has a pickup wheel. That does help with the teeth and also keeps some of the trash and dirt from ending up in the bales, too.
The feeder arm that picks the hay up from the auger at the top of the pickup reel and stuffs the hay into the plunger/bale chamber has hard, teflon-type bushings on the end of the rotating shaft. They wear out (frequently) and the arm gets pretty loose and sloppy. There were probably 4 sets of old ones in the tool box along with 10-15 shear bolts (broken).
It's a whole 'nother dimension up here in Alaska as far as prices and availability of equipment and parts. So, I just tried to head off the most likely problems that might present themselves with the baler. You shouldn't need anything more than the telephone number for your local dealer...
It's a bit different story for me! I'd betcha that you could count on one hand the number of JD 336 balers up here and you might have a finger or so left..
AKfish
/ JD 346 Baler #20
D.
The shear bolts are there for a reason. If it doesn't shear things can break that are very costly to replace. The bolts do beak every now and again just from starting and stopping the fly wheel. Or if you pick up an chunk of wood, a large stone, try to start the baler with a large slug of hay in it, if the timing gets too far off, etc.
If you search this forum for 336, and 346 you should come up with a lot of information. These balers have been discussed many times over the years here.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A64553)
2013 Volvo BL70B...
JOHN DEERE 5055E TRACTOR (A65054)
JOHN DEERE 5055E...
UNVERFERTH GW-530 GRAVITY WAGON (A64278)
UNVERFERTH GW-530...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
