Rear Finish Mower Replacement Blades
/ Replacement Blades #1
AndyG
Gold Member
SW Indiana
When I started looking for replacement blades to fit my 72" Befco RFM I thought that it would be very easy. Apparently the Befco blade is a little different because of the larger 3/4" bolt hole. This mower uses (3) 24-1/2" blades with a 3/4" hole and no offset. I am hoping to find a blade with more suction than stock or maybe a Gator blade to fit. Can you help?
/ Replacement Blades #2
worst case you may not get your gator blades, but if others are similar, just with smaller holes, have the blades drilled out with a drill press to 3/4''. This sould only cost you a few dollars for a bunch as they can stack them up and clamp them before drilling (assuming you dont have a drill press)
/ Replacement Blades #3
I have blades in stock with gullwing tips, that are 24 1/4 long and 3/4 inch hole in the middle and offset about 1/2 inch. Would that be close enough? Ken Sweet
I'm not sure Ken. I'm concerned that installing blades with an offset will cause scalping. What effect will the offset blades blades have on how the deck handles the clippings?
/ Replacement Blades #5
Theoretically, If the blade has a 1/2 inch offset in it, raising the cutting height of the deck 1/2 inch would compensate. Ken Sweet
I think that these will work. How much$?
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61568)
2013 Mack CXU613...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
New/Unused Fuel Heater (A61166)
New/Unused Fuel...
Teak Wood Table Top (A61569)
Teak Wood Table...
