B3030HSDC Hydrolick problems
   / B3030HSDC Hydrolick problems #11
I took a look at mine but Stu was way ahead of me. Was that the line your dealer replaced ? If so, they probably should have replaced that O ring when they did the line. Thankfully, the parts are cheap. Take a look on the other end of the cooler...... as I would do both O rings if the cooler has to come out. Sorry to hear about your problems with it..... my 3030 has been dead reliable with close to 400 hrs. on it.
No, the last line was under the cab,and they had to remove the cab to get at it. Thank you for assisting.
My previous New Holland was rock solid. My B3030 has been frought with issues since the day I got it, I was able to lift the front end of my New Holland effortlessly, TC21D, with the FEL, which got me out of many a mess when I would get it stuck, the Kubota struggles to lift the front, my neighbor who is a JD guy came down to help me get unstuck and couldn't believe the FEL wouldn't get me out. The A/C has been an ongoing issue and to have a leak at under 200 hrs is just grief, the broken fluid line in February when the cab had to come off, and now the blown O ring at the connection joint. I've only had it for 2 1/2 years and 200 hours. I don't do anything heavy with it, Mow and plow snow, oh yea, ruin grass each time the fluid lines blow.
Fixed it. The clip had vibrated half off, thereby breaking the seal. I found this when I pulled the clip and separated the tubes, the seal is fine, so I reconnected the tubes, pushed the clip the whole way on, started it up,and it seems to be holding, however, thats tounge in cheek because I have to put some hydrolic fluid in it, since it all ran out, to see if it leaks.
   / B3030HSDC Hydrolick problems #14
Way to go! Glad you were able to fix it!
Hopefully things will get better with your B3030....... so far mine has been doing well.
Stu
Ok, now that I have the leak fixed. I thought it would be an easy process to go to the manual and determine how much hydrolic fluid I need and where to put it.
Embarrassed to ask, but can anyone tell me how much hydrolic fluid and where it goes.
Then is the fluid something you think I might be able to get at a Lowes or Walmart?
If nothing else, I've been to tractor school these last 2 days.:laughing:
   / B3030HSDC Hydrolick problems #16
You'll find the fill plug on the center of the rear end housing at the back of the tractor........ above your rear PTO. Just to the left of the fill plug is the dipstick to check the fluid level. Both the fill plug and dipstick are yellow, you can't miss them. You'll likely need a long-ish funnel to get oil into the fill hole though. I'd recommend going to your nearest Kubota dealer and buying their (expensive) SUDT. Its what is recommended for cold weather use. If you are only concerned with standard hydraulic oil ..... you'll have to find out what Kubota specs, then find something locally that meets Kubota's specs. If it were me, I'd order a new clip to put on that line when I was at the dealer. Cheap insurance.
   / B3030HSDC Hydrolick problems #17
Unless the 3030 is unique, it will be right behind you cab next to the dip stick.
I hate to comment on fluids as I always seem to get in trouble, but I use whatever brand meets the specs, brand specific is expensive.
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
19009 (A48082)
19009 (A48082)
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
Electric Forklift Pallet (A50322)
Electric Forklift...
CATERPILLAR 140M VHP MOTORGRADER (A51242)
CATERPILLAR 140M...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
