Chain harrows
/ Chain harrows #1
Reg
Elite Member
These look SO SIMPLE that I have to believe someone has worked it out (-:
Just looking at the links and how they hook together, almost like stitches from something knitted.
Anyone figure out how to chop re-bar into short lengths, wrap them around say 2 or 3 different diameter steel pipes to bend them into shape for a harrow and hook 'em up ?
It might take 30 or 50 of them, but once the geometry is figured and the jig built I bet it would be quick.
Heck, it might even be worth buying a cheap hydraulic pipe bender from HF (-:
/ Chain harrows
I don't know how they look cause my puter must not be working right for I don't see no photos:laughing:
No offence
Your computer must be broken in a very unusual way for you to be seeing photos that are not there, as implied by your use of the double negative (-:
/ Chain harrows #5
I used to make chain armor. What you want to do is wrap a whole length of round rod around a mandrel (it'll look like a garage door spring) and cut the links off with an angle grinder as you slide them off the end.
/ Chain harrows
Thanks for your reply.
That would help me if I wanted coils or simple round links.
Chain harrow links are bent around in 3 directions and (at a guess) could probably be made by bending re-bar around a pair of pipes that are criss-crossed, perhaps it takes three pipes and maybe not at 90 degrees to each other, maybe different diameter pipes.
Again, my guess, but one could then slide the pipes out to release the completed link, which would have it's two ends as the "teeth".
I was just asking if anyone here had figured it out and could post some details.
My ability to imagine in 3D is very limited (-:
BTW, I am NOT an English teacher, or even an English major, though it is my primary language.
My initial post did not indicate that there would be pictures for the reading (of English) challenged, sorry to disappoint.
/ Chain harrows #7
Most good chain harrows are built out of high grade 5/8 inch 1060 steel because you want long life from your machine, I believe after a few uses, rebar would wear down pretty quickly. Just my humble opinion. Ken Sweet
/ Chain harrows #8
A couple of years ago, when I was shopping for a chain harrow, I ran across a video on a manufacturer's web site which showed the manufacturing process. It was pretty involved...especially assembly of the finished harrow. Sad to say, I can't find that link again (I tried, really!). I finally found a used 12-footer for a couple of hundred dollars. I'd never have been able to build one for that, even if my time was free.
BOB
/ Chain harrows #9
Sorry Reg.. but here ya go..
/ Chain harrows
Not sure if this link will work;
http://www.williamhackett.co.uk/agriculture/media/tine_action.gif
This looks like two very simple parts that could be sprung together.
The loops on the right hand end of the horizontal piece hook to the bottom of the V of the next horizontal piece, AFTER that piece has a vertical piece attached to it - repeat until long enough.
To make it "by hand" one would probably hammer the loops shut after assembly.
Thanks for the reminder Ken, every time I think through things like this you step in and remind me - or the nagging little voice wakes me up and says - "but soil is ABRASIVE !"
/ Chain harrows #11
I may be wrong here,
But I would think one would need some type of furnace to heat each rod up to a cherry red and then put it through a series of jigs to form the two different pieces,
I really do not think making the jigs would be that hard, but to handle the red hot parts, and to form them would take some thinking to make the dies and tools to make them, and to handle them hot.
/ Chain harrows #12
Those bends can be easily made cold with a two prong fork thingie clamped in a vise. Feed your round rod through a pipe cheater. The ends can be closed with judicious use of two small pipe wrenches.
/ Chain harrows
OK, I think I've done enough thunkin' on this.
Some time this week I will probably strip some solid copper wire (scraps of Romex) and hand bend it into the shapes shown on the Hackett site.
My guess is that the bend radii MATTER and they most likely have some important and fixed relationship to the rod diameter.
So, if I mic the copper wire and bend it around different drill bits until I get things right I should be able to scale it all up if/when I decide to try it on thicker steel stock.
I don't know if I'll ever get up to high carbon steel, or how thick I will be able to go if I do.
4 or 5 ft lengths of black pipe seem like reasonable bending levers, so whatever I can do with those will probably set the upper limit on stock - unless I resort to heat - and I might.
Maybe I'm not ALL done with the thunkin' part after all.
/ Chain harrows #14
Wow....the "links" some people will go to...
Mics,copper wire...radii mattering???
It's a tool to drag in the dirt!!!
I've built FELs, dump trucks,windmills...even a whole tractor using nothing but bits of string and six soybeans for measuring.....
/ Chain harrows #15
Seems it would be far quicker and perhaps cheaper to buy a used one. My neighbor has one rolled up in a fence corner that hasn't been used in over 20 years.
Harry K
/ Chain harrows
Harry K
Yep,
LOTS of them 2,000 plus miles from me (-:
/ Chain harrows #17
I made one that works pretty ok out of a piece of chain-link fence......
/ Chain harrows #19
My thoughts, Exactly!
And truck tire chains work as well or better - they are heavier. I made one with just one PU chain for smoothing a new lawn. About killed myselft trying to drag it.
Harry K
/ Chain harrows
Already done it with the chain link fence and (optionally) old tires.
That works FINE for seed beds, lawn re-seeding, etc.
I want/need something with a bit more bite in it, e.g. to break up horse manure and scratch up existing pastures.
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
1997 International 3800 School Bus (A64194)
1997 International...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
