Spirit Loader Info
/ Spirit Loader Info #1
Walter L
Gold Member
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
Does anyone have any info on the Spirit Loader. Good or Bad.
Thanks
Walter
/ Spirit Loader Info #2
They have been discussed at least once before. I found this discussion using the Search function and there may be more hits.
Thanks, dont know why I didnt do a search first, brain fade is my only excuse.
Walter
/ Spirit Loader Info #4
I have seen a few of the Spirit loaders,the are very close in design to the Koykers.I like the Koykers valve and bracket a little better,both are good loaders
Tommy
Affordable Tractor Sales
/ Spirit Loader Info #5
i just purchased a foton 404 with a spirit loader, it works fine but the legs you use to detach the loader are missing could nayone give me deminisions or information where they may be gotten
/ Spirit Loader Info #6
http://www.spiritmfg.com/
I have a spirit loader on my 284 -- has been a good loader -- have dealt with them on a pinched hose issue and got a quick response as well. COntact them directly and they should be able to direct you to the parts
regARDS
/ Spirit Loader Info #7
Have you checked the cross tubes in the loader? They are usually stored in the tubes with a clip on the end. If you can't find the info you want, let me know, as I have a Jinma 454 with a Spirit loader. They are not high tech, just a piece of angle iron with a bend in one end. I'll get some pix the next time I go to the Cabin (Wed). I have the manual for the Spirit loader if you want it. The one I have is the SL35.
You could contact Spirit directly, their Phone # is 866-533-5536, but wait till you see how simple they are.
Mgrove
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
55 Gallon Drum Dolly (A62177)
55 Gallon Drum...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
