Backhoe John deere 1050 Backhoe
/ John deere 1050 Backhoe #1
do-it
I own a JD 1050 that does NOT have a FEL. I think this is a great tractor for the uses I have for it. I may have an opportunity to purchase a JD(8B I think) backhoe attachment for my tractor, but a friend has cautioned me that mounting a backhoe on a tractor without a FEL, to stabalize the front, will undoubtely result in damage to the front end as forces are transfered. I do not forsee using this attachment extensively, but would not jepordize damage to my tractor.
Can anyone give me an honest opinion on this?
/ John deere 1050 Backhoe #2
An opinion? Sure!
For occasional light use and plenty of front ballast, you could probably get away with it.
Problem is, that "occasional light use" would probably turn into frequent heavy use.
I'm also guessing the backhoe is a 3PH unit (no subframe).
Ultimately, I think you'd break your 1050.
/ John deere 1050 Backhoe #3
An opinion? Sure!
I agree with Roy. It is not a good idea...to add to that, most backhoe subframes attach to the FEL mounting brackets so you may not even be able to properly mount the hoe.
/ John deere 1050 Backhoe #4
I have a Ford 2810 II tractor, 2WD, that I use with my 3PH backhoe-MF 1750. I have dug footers as deep as the backhoe will go in red clay, ditches, removed big rocks and stumps, dug waterways, you name it, for about 20 years. Some of the digging is straight behind the tractor and sometimes I have to dig to the side of the tractor, in tight spaces. I do not have a FEL and no front ballast except a typical Ford bumper. This is occasional use only, just a few times a year. No problems so far. But that's just my experience. YMMV.
/ John deere 1050 Backhoe #5
I think it all depends on the operator. An experienced operator who knows the limits of the tractor and backhoe, would probably be okay. But I think there is also a safety issue. Placing the bucket of the loader on the ground, just helps to stabilize your tractor and attached hoe that much more.
so... is it a good idea... probably not. Can it be done... Yes. I just don't think it's nearly as safe as having a loader on your tractor.
CATTLE HEAD CATCH (A62130)
CATTLE HEAD CATCH...
PALLET OF ARMSTRONG CEILINGTILE (A62131)
PALLET OF...
2019 FREIGHTLINER CASCADIA 6X4 TANDEM AXLE SLEEPER TRACTOR (A59909)
2019 FREIGHTLINER...
2018 Ford F-150 4x4 Pickup Truck (A61568)
2018 Ford F-150...
JOHN DEERE CART (A62131)
JOHN DEERE CART...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK02CK16471 (A61165)
2002 Freightliner...
