Ford555 BACKHOE THROTTLE LINKAGE HELP
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #1
m335
Hi guys,I am in the process of restoring a ford 555 4x4 backhoe machine(1984.)can here anyone here send me a pic of the throttle linkage down on the gearbox,under the fuel tank.I have afew bits missing I think and need to see what it looks like when its together.The manual I have has a very poor black n white photo but I cant make anything out from it.From what i can see its has the foot throttle connecting somehow to a plate that is connected via a rod to the hand throttle lever?
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #2
Call Matt Porter at Schaefer Enterprizes 1-800-626-6046 or email to mattp at sewiparts.com. Matt has help me come up with parts as I am working to do a "working" restore on our 1983 JD backhoe. They are a heavy equipment graveyard and can get some new after market parts too.
Schaefer Enterprises Inc. - Home
Have your model and associated numbers. They are only about 100 miles from me but they ship UPS all over the country. I drove up the first time just to check them out and they passed in flying colors. My son was playing with a flying toy of my daugher's and landed on the awning across the front and two employees took a pallet and a forklift and retreived it for her. She was happy too. :D
Ah thanks,but Im in Scotland,Ill email them just in case they can send me a photo though :)
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #4
Sorry I thought you were looking for missing parts for your back hoe. Get you a factory manual off of Ebay with good pictures if you can fine one. I found CD manuals can be more clear and you can zoom them.
Yes,I got a manual ,its a usa printed book,and its around 2 inches thick,but the one photo i need to see clearly is just too dark and small lol,need a good clear colour pic of it just so I have an idea what ,if any parts are missing,I removed the engine and stripped it down a year ago,so its just being put back together now after its rebuild,unfortunatley,I never saw the machine working and cant be sure if the foot/hand throttle were working as they should.
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #7
I have a 555C 4wd of about the same vintage.
Will be a couple days and I can look take pictures if needed.
PM me would probably be best to remind me if I do not see this thing hit the top of the list again, not usually one I look at here.
I have the book from the UK as well so might have the answer there but the online above has pretty dang good pictures.
PM me if you need something additional.
If you could,that would be brilliant Alan,I tried the link above,doesnt seem to open for me,keeps asking for a 'dealer login'?
A picture of the linkage under the tank,so I can see how it went together will be just the job,thanks again!
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #9
Go find Nashville tractor's website (google is your freind) and their parts department and then they have the link there as well or Messicks does as well (I imagine that any NH dealer has it available)
I will look at what I can see, but pictures under the fuel tank are hard for me to visualize. Will look when I am home.
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #10
Go here, I use them all the time for my 655:thumbsup:
Enter "Construction" portion and enter your model 555 and you should be able to see how everything attach's.
New Holland Parts
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #11
I know you said it in the first post, but without some fairly serious deconstruction I don't see how to get in there for a picture.
The gas pedal goes into the firewall and enters the land of away.
Any luck looking on the websites?
no luck as yet,tried these two sites,but nothing,and to add more confusion,it seems the U.S spec 555's have quite afew diferences,some U.S models dont even hav a cab,only a roll cage.
Anyway,I have found that there is deffinatley a part of the hand lever linkage missing,the linkage comes through the firewall from the dashboard,down (behind the fuel tank) to the linkage that pivots on the gearbox,here the hand linkage rod connects to a ball socket,and from the other end,via another ball socket and rod to the fuel pump.part of this linkage is missing on mine as theres only one ball socket,possibly this is that part that links up the foot throttle(gas pedal) also.This was never connected as far as i can remember when i got the 555,so I have no idea what the part looks like.If i can get it hooked up with fabricating my own brackets and have it working on the hand throttle for now ,ill be happy.
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #13
Nothing???????
New Holland Construction 555A 3 CYL TRACTOR LOADER BACKHOE
It looks like the complete linkage schematic along with the part numbers and pricing if needed.
:confused2:
The dropdown lets you select which 555 you have and if you think its about and 84 then it should be a 555a.
haha!!thanks Slan!i looked and looked!:p
well well,theres whats missing...number 34 and 39 being the main parts,although...something rings a bell about number 34...ill have to search the parts boxes .....!
/ Ford555 BACKHOE THROTTLE LINKAGE HELP #15
No problem, it's amazing how a "Mystery Part" can hang around for a long time until one day "So thats what thats for"
My dozer came with a box of them as well and until I got the service manual they were a mystery to me as well.
Good luck with your 555.
I know my 655 has been one of the best pieces of equipment I have ever owned even after I dumped it into my pond.
Just keep the front hydraulic pump ujoints well lubed.;)
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
International...
30in. Forks and Frame Mini Skid Steer Attachment (A59228)
30in. Forks and...
1608 (A57192)
1608 (A57192)
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Hydraulic Skid Steer Auger Attachment with Bit (A59228)
Hydraulic Skid...
