New R28 Montana with Back hoe
/ New R28 Montana with Back hoe
It is a diverter but I can still operate the up and down function of the loader. If you hold the joy stick at angle you would be able to operate 2 functions at once. That is tilt up the bucket and lift the arms all at once or the same in reverse. Same here with the loader control. Lift the loader and run the auger at the same time just by having the joy stick at an angle.
/ New R28 Montana with Back hoe #22
Did you also get the hydraulic reservoir?
Roland
I have the Montana brand MBH76 hoe a full 8ft depth to the end of the bucket. So far it works very good. I would have liked to have .
What reservoir?
Only reservoir I know of is what the tractor already has. If your back hoe doesn't have fluid then the fluid from the tractor's reservoir will have to pump it into the hoe.
Make sure you fill the tractor reservoir.
/ New R28 Montana with Back hoe #24
I probably misspoke :confused:what I meant to say was PTO driven with a reservoir.
What reservoir?
What kind of back hoe do you have?
Reason I ask is because all the 3pts I have seen use the hydraulics from the tractor.
I can't imagine one being run by a separate hydraulic drive off the pto, there is very little room behind the back hoe.
/ New R28 Montana with Back hoe #26
I don't have it yet. But its an MBH 7.6 (Amerequip branded Montana). The resoivoir is under the seat so there is no more space taken up.
Mine doesn't have a reservoir it is driven by the hydraulics from the tractor.
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
Bobcat A770 (A60462)
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
Peterbilt 377 Semi-Truck (A61306)
Peterbilt 377...
2022 Horizon Trailer (A55973)
2022 Horizon...
Deere 310L (A53317)
Deere 310L (A53317)
