Decent fuel can/Jug
/ Decent fuel can/Jug #1
Tarheeler
North Cacalacky
Kubota l2800hst
So where do you find a decent one at-- Looked at a metal one at TSC @ 35$
The plastic enviro's look like junk - my 2cent
/ Decent fuel can/Jug #2
/ Decent fuel can/Jug #3
Look for one of the plastic green/tan military surplus cans. Those work great and are usually less money than any of the carb-compliant crap you have to buy now.
/ Decent fuel can/Jug #4
I love the Jegs page. "Utility Jugs" which are not intended for gas, diesel or kerosene. Available in red,blue and yellow. HA! Awesome.
/ Decent fuel can/Jug #5
until recently, I used the JEGS and had very good success with them. The way I used them was to hoist the jug onto the hood, next to the fuel tank filler (Kubota L4330) and then I used this barrel pump
Northern Industrial Barrel Hand Pump | Barrel + Hand Pumps | Northern Tool + Equipment
I cut it down to just fit into the JEGS and then it will siphon in 5 gallons or so quite nicely...so, one hefty lift and no pumping and no spills. When I cut the input pipe I cut it on a diagonal, which leaves a little in the JEGS (where the water/gunk is).
/ Decent fuel can/Jug #6
Canned the can thing a few years ago with this an never looked back.
/ Decent fuel can/Jug #9
It was only a matter of time.......
/ Decent fuel can/Jug #10
I use a MotoX fuel jug very heavy duty plastic with large fill hole and fill tube,
Holds 5 gal. can be purchased at any of your cycle dealerships for around 25-30 bucks in an assorted of colors, I have Green.. as in KX Green :D Have had it for at least 12 years and still as strong as the 1st day, looks like this --->
actually looking back at these they do not look as heavy duty as what can get 10/12 years ago.
mine has a 3/4 in tube ,
/ Decent fuel can/Jug #11
Those look almost like the JEGS cans at $20. They are very heavy duty.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2019 Terra Gator TG8400 Spreader (A63111)
2019 Terra Gator...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
8' DISC HARROW (A60430)
8' DISC HARROW...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
