Decent fuel can/Jug
/ Decent fuel can/Jug #1
Tarheeler
North Cacalacky
Kubota l2800hst
So where do you find a decent one at-- Looked at a metal one at TSC @ 35$
The plastic enviro's look like junk - my 2cent
/ Decent fuel can/Jug #2
/ Decent fuel can/Jug #3
Look for one of the plastic green/tan military surplus cans. Those work great and are usually less money than any of the carb-compliant crap you have to buy now.
/ Decent fuel can/Jug #4
I love the Jegs page. "Utility Jugs" which are not intended for gas, diesel or kerosene. Available in red,blue and yellow. HA! Awesome.
/ Decent fuel can/Jug #5
until recently, I used the JEGS and had very good success with them. The way I used them was to hoist the jug onto the hood, next to the fuel tank filler (Kubota L4330) and then I used this barrel pump
Northern Industrial Barrel Hand Pump | Barrel + Hand Pumps | Northern Tool + Equipment
I cut it down to just fit into the JEGS and then it will siphon in 5 gallons or so quite nicely...so, one hefty lift and no pumping and no spills. When I cut the input pipe I cut it on a diagonal, which leaves a little in the JEGS (where the water/gunk is).
/ Decent fuel can/Jug #6
Canned the can thing a few years ago with this an never looked back.
/ Decent fuel can/Jug #9
It was only a matter of time.......
/ Decent fuel can/Jug #10
I use a MotoX fuel jug very heavy duty plastic with large fill hole and fill tube,
Holds 5 gal. can be purchased at any of your cycle dealerships for around 25-30 bucks in an assorted of colors, I have Green.. as in KX Green :D Have had it for at least 12 years and still as strong as the 1st day, looks like this --->
actually looking back at these they do not look as heavy duty as what can get 10/12 years ago.
mine has a 3/4 in tube ,
/ Decent fuel can/Jug #11
Those look almost like the JEGS cans at $20. They are very heavy duty.
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
208315 (A58376)
208315 (A58376)
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
