Loader using fel
/ using fel #1
wade simpson
dartmouth nova scotia
kioti ck20s
IN the manual for the kl120 it said not to tip the bucket fwd to pull earth while going backwards. It said it could damage the tipping cylinders. It seems as tho everyone does it tho. Is it a common sense issue or is there a good chance of damage?
/ using fel #2
It is a standard backdragging technique to "dump" the bucket then drag it along in reverse. However, when you dump the bucket the dump cylinders are fully extended and therefore vulnerable. I recall that is the way damage can occur. Bottom line is that if you are backdragging loose soil/gravel/sand it should not be a problem but you would not want to snag a stump or curb as that could twist the bucket and potentially damage the dump cylinder. That is my read anyway.
/ using fel
That's the way I understand it as well. The earth I'm moving is a mixture of rocks, clay, and soil. I use the loader to drag the dirt of the the top of a rise then scoop it up. Works great but occasionally there are rocks that lift the fel as it drags over them.
Maybe I do more shovelling to loosen stuff up prior to dragging it down.
/ using fel #4
That won't hurt anything. It is slamming the bucket into a stump or curb that is more likely to do damage. Riding up over a rock as it is dragged along will not deliver a shock load.
/ using fel #5
When you are dragging with the bucket and the curl cylinders are fully extended, they are in compression. When in compression, there is not much strength as they are acting like a column (thin column at that). If you catch something, that "column" can easily bend. If the bucket is not curled all the way back, then backdragging isn't as risky.
I do it, but am very careful and slow if I use the bucket edge like a blade. Moving forward, then these cylinders are in tension which is not a risk to bending them.
Just know the risks, and you should be ok. :)
/ using fel
That's great..Man, I really wasn't looking fwd to much more shoveling. I still have to shovel sometimes, big rocks roots, etc but at least not the whole job. Kept me in good shape...well..except my back..shoulders (smile).
/ using fel #7
Can you back drag with the flat part of the bottom of the bucket instead of fully tipped? The results should be the same.
/ using fel
I was doing that at first but it wasn't very efficient. I only do the after I've dumped the dirt on the road. To loosen the dirt or remove overburden to get undisturbed dirt from the top of a rise or pile I have to bury the edge of the blade around 1 in then drag it. The bottom works great for flattening and slightly compressing the dumped load
/ using fel #9
One point that made not have been clear enough: back drag but do so without extending the cylinders (full dump) all the way out. The shorter the exposed cylinder (less dump angle), the less likely there is of damage. I've done it plenty, but never with more than about 50% of dump angle. Use common sense and don't push your macine to do things it wasn't meant to do.
/ using fel
I just read an article here about a fella that bent the half moon parts of the fel. There may have been another problem but it may have been partly caused by using the bucket to backdrag at too great a down angle. I think I'll try again with the bucket a little closer to parallel. In that discussion a down angle of 30 degrees was mentioned, perhaps a wiser method.
Thank you all for advice
/ using fel #11
The manufacturer is covering their "arse" by stating that they can't control the loads you place on the cylinders with the tractor. The previous poster is absolutely correct in that the "column strength" of the cylinders is greatly reduced as they near full extension. If you retract the cylinders just a few inches their column strength increases dramatically. The column strength vs. stroke curve is like an upside-down back-flip jump! From what I gather, you're probably fine doing what you've been doing.
One of the significant things that helped me choose Kioti was the cylinder dimensions as compared to the other "equal" brands. Look at the Branson or Mahindra FELs.
/ using fel #12
It is not as much that column strength decreases with extension [it does], but that the leverage of the bucket on that column increases astronomically with the bucket way outcurled. Take a look at how the pivots line up.
larry
/ using fel #13
I have done just about everything you shouldn't do with my FEL and haven't damaged the cylinders. I did have the cracks that everyone gets with the early loaders and have added the brace. I have back dragged with the bucket fully curled and the front wheels off the ground, dug rocks with the corner of the bucket that lifted the rear end. I use it to dig up sod all the time and have never bent anything. All I can say is they sure built my CK20 tough cause I can't break it.
A farmer friend tells me what I shouldn't do but he doesn't own a Kioti.
FC
/ using fel #14
FC
No way my loader will pick up the back of my CK25. Hits the relief every time well before the rear gets light (I do have loaded tires), even with no implement on the back. Another reason these two can't be compared when it comes to loader use. The bigger CK will push it to the limit more easily due to its extra weight. For this reason, I wouldn't over stress my loader by backdragging with it fully curled. Nor would I pry with one corner of the bucket. Just isn't necessary, and too expensive to take the chance, for me.
/ using fel
I won't push it too hard either. I'd be hooped if I broke the fel and the way my luck goes I'll be the one to have the one in a hundred break.
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
iDrive TDS-2010H...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
JOHN DEERE 6605 TRACTOR (A63291)
JOHN DEERE 6605...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
