homemade tractor
/ homemade tractor #1
neon_c2
Member
I'm just posting these pics of the tractor my friend got. It's not running right now but it just a cool little thing. It's a liq cool four cylinder with two chevy transmission and a Ford 9" rear end. Has two brakes and a parking brake. There a build in loader, the frame doubles as a hydraulic reservoir. It might be the same size of a 8n ford or smaller.
/ homemade tractor
I know I hope my friend get it running. I can try to get a few more better pics of it next time I'm at his shop. Sorry we don't know anything about it. Or who made it. But it is build heavy duty.
/ homemade tractor #4
Look for CONN in raised letters on the side of the block or head.
The distributor and oil filler/breather position looks like maybe an 801 Ford engine. It clearly has a valve cover so it has overhead valves.
/ homemade tractor #5
Look like a fun project. Not that it really matters, (unless you need to find parts for it, that is), but Ford 9" axles unload their internals from the front. The bolts on the rear of this tractor's axle identify it as something other than a 9" Ford.
Typical Ford 9" housing viewed from the rear:
And from the front, showing how the everything unbolts and drops out:
/ homemade tractor #6
Gotta love them disc brakes:thumbsup:
Mark
/ homemade tractor
brokenot: your right on the axles I don't think it a 9" ford I have to take a 2nd look at it again. Those open rear disk brakes are big.
/ homemade tractor
I guest the guy that had it before said if you put the first transmission in high then the 2nd transmission in high it would go over 50mph. Not something I would like to try.
/ homemade tractor #9
Just wear your seat belt. :D
Actually who ever designed this tractor either had a lot of skills/abilities or would have made a great engineer with the right training. It is not easy to do a project out of materials at hand or from the junk yard. I am impressed.
/ homemade tractor
Funny thing last night I was talking to the farmer brother I help on the phone last night. I said something about this tractor and he said I bet I know who made it. He knew alot about it. The guy that made it work at the same place. Caterpillar shop by Des Moines. He was the head welder for them and retired from there.
It a Ford Pinto engine in it.
/ homemade tractor #12
Looks Part tractor and part dragster
/ homemade tractor #13
I would keep asking around since I am sure he is wrong about the engine.:D
/ homemade tractor #14
Gale is right. Pinto engines (as I remember) had an overhead cam-meaning that you'd not be able to see the front of the valve cover because the sheet metal timing belt cover would be there.
Is it one of those four bangers that GM used in the Monza, Sunbird and some of those other 4cyl RWD cars?
/ homemade tractor #15
/ homemade tractor
Gale Hawkins: I look at that tractor you posted on ebay. That might be the motor in the homemade tractor. I stop by the shop. It has to be a tractor engine it has a governor on it.
/ homemade tractor #17
Plus it has been 70 years since they built a car with a updraft carb .:D
CONN will be stamped on it some where. Ford and MF used this engine for many years but it could have come off a ride at an amusement park, water pump, backup generator, electric welder, etc. There are millions of them around the world.
continental gas treactor engines - Antique Tractor Talk
Some info that may help ID the engine.
TractorData.com Massey-Harris 44 tractor engine information
Possible source tractor.
Monte's Equipment Company
Uses of engine and place for parts.
http://www.wisconsinmotors.com/partc/con_engines/L-Head_Overhaul.pdf
CONTINENTAL L-HEAD ENGINE MANUAL
I do not think this is for your engine but it is a complete rebuilt manual that will be nice to have for some people. It actually has pictures of the engines it covers.
FOUR CYLINDER
N56 -- N62
Y69--Y91--Y112
F124-- F135-- F140-- F162-- F163
SIX CYLINDER
F186-- F209-- F226-- F227-- F244-- F245
M271 -- M290-- M330-- M363​
B371 -- B427
/ homemade tractor #18
I like the bucket design! I've always wished my buckets were deeper and not so wide. That makes it a lot more versatile for dirt work.
The operator won't have to worry about heavy brush damaging his fenders.
Judging by the seat, it was a real worker, not just a hangar queen. :laughing:
/ homemade tractor
The fenders are 1/4 plate steel. It needs a floor pan, you don't want a lose shoe lace. The drive shaft is right by your feet.
