tallyho8
Super Member
- Joined
- Aug 1, 2004
- Messages
- 5,258
- Tractor
- Kubota L4400, Kubota ZD326
After having a slow diesel drip in my beloved 1995 F250 powerstroke that I keep in mint condition, I determined that the chances are 99% that it is leaking out the weep hole in the fuel pump and decided to change it. The dealership wanted $1025 to change it and I was able to get all the parts for about $140 so I decided to do it myself.
The pump is in an extremely crowded area in the valley of the powerstroke where you can't even see it without a lot of trouble. I found good instructions on line and went and bought all the parts I needed ahead of time.
I followed the instructions and everything seemed to be going perfect when I finally started pulling up on the pump very hard to remove it from the valley. I thought I was pulling it straight up but must had pulled it sideways a little because the bottom of the pump broke off flush with the valley and remained stuck in it while I removed the pump. (see first photo)
When I saw what had happened I immediately had visions of drilling and ez-outs and metal filings going in my crankcase or a multi-thousand dollar repair job. (See second photo) I lost control and yelled a few choice words and caught myself just before I threw a hammer through the windshield.
After I calmed down I realized that it might not be as bad as I thought. First, I turned the engine over to see if the cam would push it out. No movement. Then I realized that the outer ring was a rubber o-ring and I got my snap-on pick and was able to remove it. Then I was able to push the outer part down a little so that the tappet shaft stuck up a little where I could get a small vice grip on it and pull up and remove everything.
(photo3)
I was so thrilled that a calamity had been averted that I decided to have a couple of adult beverages and quit for the day and unwind. Everything is out now and so tomorrow I will have the whole day to see if I can put it back together again. Wish me luck!
