Need a good come-along
/ Need a good come-along #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've searched, fairly fruitless.
Right now I'm pulling a stump. Before I've pulled cars and my Ford Diesel Maxi-van.
I've got one of those $40 HF specials rated at 3,000lbs.
All I can find in my area are other HF style low quality mfg. pullers.
I don't want an electric winch that will haul the Washington Monument to the moon.
But I'd like to have something manual that could crank 5 ton and be built strong enough that I can plan my son can pass it down to his grandson. (I've a bunch of tools my Grandfather passed to me which are destined for future generations.)
Any links?
/ Need a good come-along #3
The link above says it will pull 6ton (line doubled), or lift overhead 3 ton.
/ Need a good come-along #5
I have been stuck on two stumps so far this year and was stuck in the mud once. Each time I needed a good portable puller...and it took me hours to get free.
I just ordered a More Power Puller (two ton) from Wyeth-Scott. I have owned the cheapies....and I want a good one that wont fall apart and has a reasonable length of line pull. Thanks for reminding me. :thumbsup:
Try looking at the more power puller at The Wyeth-Scott Co. - portable winches | cable puller | come along winches. I have one of these that I use for cutting down trees and getting my F150 unstuck. They are made of ductile iron. They are not rated to pull 10k pounds but you can make up the difference with proper rigging.
Thanks Hillfarmer, one 3 ton on order. Hopefully my heirs will raise thanks to you many decades from now.
/edit - and for those of you looking for something new they have a rope called Amsteel Blue which is supposed to be as strong as aircraft cable.
/ Need a good come-along #8
WOW!
I am glad that I didn't just buy that JET brand lever chain hoist I had my eye on, although for my use that may be a better option (more controllable).
Well, due to necessity I also bought the HF $26 special. Stamped metal, really inexpensive construction. I've got it pulling on a stump right now. Good enough to throw in the truck, probably not good enough for posterity.
I apologize a little for "getting on a soap box", but there will always be a need for "simple tools", levers, manual saws, rope, etc. Some tools reach a maximum level and plateau (the 5 lb sledge) and a good one can be passed down for generations (oil the handle).
Right now the grinder I use to sharpen lawnmower blades and big knives is a system cobbled together by my grandfather based on a 1926 refrigerator motor. It WORKS. A few squirts of oil annually.
To me there is a satisfying essence wrapping my hands around a tool my Grandfather first used 70 years ago, and I use today.
/ Need a good come-along #10
I have my grandfather's cross-cut saw and use it often, along with a few simple hand tools and a Rockwell radial arm saw that is rarely used.
/ Need a good come-along #11
I just bought a close out 'commercial grade' Massdam unit like the Wyeth unit. Hadn't seen one like that before. Our local Big R had them for $76. Figured it beat the ~$40 units on sale (that look just like the HF junk I own already). But man -- you will be a man if you lift that thing often!
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
Case 1150G Crawler Dozer (A66285)
Case 1150G Crawler...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
