Belts needed
/ Belts needed #1
Schroegeo
I have an old MTD. I removed a bad drive (trans) belt and main deck belt the other day and decided to skip on day down and grab a couple more right quick. Now I have two foot tall grass and a dead MTD shell out front. Local mower shop can't find this Model No. anywhere, so they call the expert and he can't find it. MTD personel (some kid) says "There's no such number." told me all the model nos. are under the seats, mine is under the hood cover.
TMO 33566A is the elusive no. Anyone know what my next step should be?
/ Belts needed #2
Have you tried Jack's Small Engines? They stock tons of parts and I have found them to be very knowledgeable and helpful. They may be able to figure out which belt you need:
jackssmallengines.com
/ Belts needed #4
MTD model number 139-758-088 the belt that you need is a 954-0248 or 754-0248 mtd list 44.37
/ Belts needed #6
Ken, I believe these P/Ns cross reference to a 1/2 x 89 V belt.
Can you cross reference a Western Auto #248089 or #754-0248? Or maybe Stens?
/ Belts needed #7
Just take your belt to the auto parts store and have them measure it. I just got a belt for my Craftsman Mower for $9.99 at O'Riley Auto Parts. It was $35 at Sears.
Chris
/ Belts needed #8
Something that i have discovered about lawnmower belts is just because it cross references to a 1/2 x 89 doesn't mean it is 1/2 wide or 89 inches long. Have run into cases where 1/4 can mean the difference between working and not working.
/ Belts needed #9
Still don't come up. I need the # off the belt. I have a guy that works for me that put white talc powder on the # area on the belt, got out in the sun with a magnifying glass and got the #. He is back to mowing. Ken Sweet
/ Belts needed #10
got the MTD model number from the mtd/montgomery ward cross reference. Try typing just the 139-758 into the parts lookup since the last three numbers are the code for who it was manufactured for.
/ Belts needed #11
Chris
I have a MTD and also couldn't find the drive belt number listed in the catalogs. I did just what Diamondpilot suggest. I took my almost completely distroyed belt to a Do It Best hardware shop (like an Ace hardware) and they were able to measure it on a little belt measureing device. The new one fit just right. It was about $10 too!
jb
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
2019 Bobcat E85 Excavator (A63109)
2019 Bobcat E85...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
